Thread: How many speakers can I add? |
New member Username: Tofer
New York,
NY
United States
Post Number: 1 Registered: Mar-07
| Posted on Friday, March 09, 2007 - 01:53 pm: |
Very basic question. My girlfriend has a Sony "Executive Stereo" ;) with tape,CD, etc. There are two black(neg) and two red (pos) "slots" for the speaker wire. This is fine for the two speakers included. She has a second set of bookshelf size speakers that she likes because the screens are faux book spines. Can I attach them with the current speakers by running the wires in as well? i.e., two wires per "slot"? |
Platinum Member Username: Project6
Post Number: 13739 Registered: Dec-03
| Posted on Wednesday, April 11, 2007 - 03:35 pm: |
You can but, don't. Just use the speakers she likes. You gain nothing by connecting another set of speakers in the same output. You risk overdriving the unit. |
New member Username: Jmz
England
Post Number: 2 Registered: Oct-08
| Posted on Friday, October 17, 2008 - 05:18 am: |
I've got an ancient Pioneer stacker system, and I have two sets of huge speakers, 2 Jamo and 2 Kenwood, as it only has a left and right output I've put one of each speaker on both channels, a speaker in each corner of the room flat on it's back(cone facing up)respecting left and right and it sounds superb. I've never felt the need to replace the setup as it is loud and clear with great bass. Left - Jamo & Kenwood Right - Jamo & Kenwood |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 454 Registered: Feb-08
| Posted on Friday, October 17, 2008 - 07:20 am: |
Greetings James, There are impedance issues to deal with when attempting to hook more than one speaker to an amplifier output. You will find impedance ratings on the labels and the math (and further explanation) can be found here: http://www.bcae1.com/spkrmlti.htm |
