Thread: Highlander 100 w subwoofer |
New member Username: Spadej
Post Number: 1 Registered: Mar-07
| Posted on Wednesday, March 07, 2007 - 07:16 pm: |
Hi, Im a novice on this topic.. Could anyone please help me.. I have a 100 w subwoofer( active) Frequency response 10hz-120hz(+-1db) sub woofer channel rms 4.....100w rms..8.....60w Frequency 50hz rated power <=200w normal power <=100w It has a phase control 0 degrees to 180 degrees a crossover control40 mhz to 180 mhz and volume control min to max Firstly... does my subwoofer need an amplifier or something else for it to work.? How do I "tune the subwoofer" in using the above controls? thnanks JAmes |
Gold Member Username: Arande2
Extreme SQ FTW
Post Number: 1842 Registered: Dec-06
| Posted on Wednesday, March 07, 2007 - 07:23 pm: |
No amplifier needed. Just dial the phase until it sounds the loudest, crossover control...take off the m there...and a lot of those specs seem way off. Turn the crossover where your speakers let the sub take over (probably 80hz). The volume you just turn until it sounds even with the rest. IT all really depends on what you plan on hooking it to. |
Post Number: 2 Registered: Mar-07
| Posted on Wednesday, March 07, 2007 - 09:27 pm: |
Hi Andre, thanks for your help... Another thing.. Im hooking the sub woofer up to the tv.. Im also trying to hook 2 speakers to the subby.. but the speakers dont work... Am i suppose to hook them up on the input or out- put connectors of the subwoofer? thanks james |
Extreme SQ FTW
Post Number: 1843 Registered: Dec-06
| Posted on Wednesday, March 07, 2007 - 11:00 pm: |
Does your TV has speaker-level outputs? These are usually clip spring terminals on your TV. If not, you're not going to get your speakers any power that way... If your TV does have speaker outputs, then I'd recommend hooking speakers straight to the TV and the subwoofer to the TV's Variable audio output. Would you mind telling what the sub and speakers are to make sure I'm not telling you the wrong stuff? |
Post Number: 3 Registered: Mar-07
| Posted on Thursday, March 08, 2007 - 04:38 am: |
the speakers are 5.1 channel multimedia powered speakers. It also has a subwoofer 30watts. which is not what i want. thats why i got a 100w subwoofer. The 100 w subwoofer brand name is "Highlander" . thanks james |
