Thread: Bose Cube Speakers |
New member Username: Jim_brown
Post Number: 1 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 11:57 am: |
I need some guidance. I currently use JBL speakers on my rear channel. I am thinking of replacing them with Bose cube speakers. What I need to know is will the speakers work fine without the bass module or do they have to be connected as to mfg. specs. My main speakers are 301's and a 150w sub. Thanks, Jim |
Gold Member Username: Thx_3417
Bournemouth ...
Post Number: 3040 Registered: May-05
| Posted on Monday, March 05, 2007 - 01:08 pm: |
Bournemouth ...
Post Number: 3041 Registered: May-05
| Posted on Monday, March 05, 2007 - 01:10 pm: |
Stick with JBL it’s the best it’s the first to have been used in the cinemas it the best all round sound. |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 426 Registered: Apr-06
| Posted on Monday, March 05, 2007 - 01:36 pm: |
To answer your question, you don't want to hook the cubes up directly to your receiver. The bass module has a crossover built into it which adjusts the output for the attached cubes. |
