Thread: Amp right volume knob has to be wiggled to get right channel to work? |
New member Username: Buckstar
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 04:44 pm: |
Having trouble with my Yamaha M-65 amp. I have to wiggle right or left volume knob to get right channel to work? Anybody have any idea what the problem is? Thanks in advance! Buck |
Relevant Product Info
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9925 Registered: May-04
| Posted on Sunday, March 04, 2007 - 05:57 pm: |
. The control is either dirty or needs replacement. |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 07:14 pm: |
Thanks Jan, Do you know if cleaning/replacement is easy, DIY? |
Gold Member Username: Nuck
Post Number: 6193 Registered: Dec-04
| Posted on Sunday, March 04, 2007 - 11:02 pm: |
Sure it is easy, Brian. If you are handy with a soldering iron, you can do it. If you have not had your Yammy open before, you might not be as adventurous as at first blush. If it works OK otherwise, you might dop a few bucks and have the unit serviced and cleaned by a shop. Or a grade 12 high school class. I've done that. |
Dallas,
TX
Post Number: 9927 Registered: May-04
| Posted on Sunday, March 04, 2007 - 11:39 pm: |
. I don't remember if the pot is sealed or open. If it is sealed, you'll not be able to do much with spray type cleaners. In that case a technician would be the one to do the job. If you can get some spray type tuner/contact cleaner inside the pot, you can usually clean it by just spraying and working the knob back and forth. Yamaha no longer supports the older products with parts so you might have problems if the pot must be replaced. However, volume control pots are fairly similar in nature and you'll have to know the impedance of the stock OEM unit and the shaft dimensions should you go looking for a replacement in the aftermarket. Some pots will have the impedance stamped on the case of the pot, look there first if replacement is called for. Replacement is a fairly straight forward job but, if you haven't had you hands inside an amplifier before, I would let a technician do the work. There are lethal voltages inside an amplifier just as the warnng labels suggest. And, if you don't solder well, a bad solder job is worse than a wonky pot. . |
