Thread: Need help |
Bronze Member Username: Shawnharman
Post Number: 65 Registered: Dec-05
| Posted on Sunday, March 04, 2007 - 12:50 am: |
I have an old receiver, that the amp wont click on, there are 4 fuses near the amp on the inside, 2 near the relay and 2 near the transformer, but I discovered just recently that when I remove the 2 fuses near the relay, the amp clicks on, but I get no display, but when I put the fuses back, I get my display, but no sound or click from the relay. can anyone help me with this?? thanks for any help. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9923 Registered: May-04
| Posted on Sunday, March 04, 2007 - 08:17 am: |
. A technician probably could. The relay has probably gone bad and should be replaced. A technician can determine whether my guess is correct. |
Post Number: 66 Registered: Dec-05
| Posted on Sunday, March 04, 2007 - 12:44 pm: |
thanks jan, thats actually the same thing I was thinking, but I was hopeing it was just the fuse. But I do have the same model receiver for spare parts, Do you think I will be able to switch the relays out, I can do it myself, cause im really good in that area, and a tech said the same thing that you did, so I think I will check it out. thanks again. |
Gold Member Username: Nuck
Post Number: 6188 Registered: Dec-04
| Posted on Sunday, March 04, 2007 - 02:07 pm: |
Shawn, if you are good in that area, you wouldn't need to ask. Solder the spare into place, you might want to use a solder sucker instead of a wick, considering spread. Good luck. |
