Thread: Kenwood VR406 surround sound issues |
New member Username: Dangergirl
Post Number: 1 Registered: Mar-07
| Posted on Saturday, March 03, 2007 - 03:24 am: |
Hi, I tried setting up the surround sound on my kenwood receiver but having problems. When testing the speakers they all seem to work but only the front r/l speakers work when the receiver is being used. The receiver only shows the r/l speakers on the screen and no matter what buttons I push, I can't get the center, sub or rear speakers to work. Can anyone offer any suggestions how to fix this? Thanks! |
Gold Member Username: Nuck
Post Number: 6121 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 09:17 am: |
Kim, what input source are you using, and into which connections? Your player may not be configured properly for 5.1. Have you check the connections section of the manuals? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9906 Registered: May-04
| Posted on Saturday, March 03, 2007 - 12:16 pm: |
. I assume this is a new receiver. If so, dealer support is your best choice. Can I assume you paid for that feature/benefit/advantage? |
Post Number: 6130 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 03:04 pm: |
Again, here it comes. Like I said before. How is your dealer helping you? |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 11:36 pm: |
This is a used system. I got it several years ago. |
Dallas,
TX
Post Number: 9929 Registered: May-04
| Posted on Sunday, March 04, 2007 - 11:48 pm: |
. Do you have the owner's manual? |
Silver Member Username: Bill984
Post Number: 245 Registered: Oct-05
| Posted on Monday, March 05, 2007 - 07:06 am: |
get the manual here http://www.kenwoodusa.com/support/simple.aspx?men=2&M2=69 |
New member Username: Candyd
Post Number: 1 Registered: Apr-07
| Posted on Sunday, April 01, 2007 - 08:40 pm: |
How do you turn the mute off on the VR406? It doesn't have a mute button and I have no idea how it got turned on. |
