Thread: Speaker glue |
New member Username: Dustcanblue
Post Number: 1 Registered: Mar-07
| Posted on Friday, March 02, 2007 - 05:12 pm: |
Hi Guys I have a set of Paisley SPL monitor the foam on the outter edge of the speaker detach itself from the cone wich is somekind of plastic. The foam is not damage at all. I was wondering if somebody had the knowledge of what kind of glue they used or tips on how to fix that. Any help would be greatly appreciate. Thank you. Robert |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9904 Registered: May-04
| Posted on Saturday, March 03, 2007 - 12:10 am: |
. Try contact cement. Be careful, once the two pieces touch, they are forever bonded in that spot. |
Gold Member Username: Nuck
Post Number: 6116 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 08:52 am: |
Robert, I had those. Do you have 10's or 12's? Nobody else has heard of them, and API does not stock parts. Ian Paisley did a wonderful job on these as an upper line to the Acoustic Research line that API was using his name for. Those Paisley's were all his design. |
Post Number: 6117 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 08:54 am: |
Try nail polish on similar materials before hand, It is not so flexible, but will not crack. |
Dallas,
TX
Post Number: 9907 Registered: May-04
| Posted on Saturday, March 03, 2007 - 12:18 pm: |
. "Try nail polish on similar materials before hand ... " Good one, Nuck. |
Post Number: 6135 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 03:34 pm: |
The bass player punched one of the Marsland bass bins on the way out, I mended it with the nail polish(yes, pink), but that was a cardboard Marsland 200w 15" driver, with 120 oz magnet.I spotted the suspension(neo or something close) with the polish as well. I believe in the nail polish, at least for low drivers. BTW, he hit it as hard as he could, one little crack in the surface. Them be tough. BTW, I also banged the chick that donated the nail polish. |
Dallas,
TX
Post Number: 9915 Registered: May-04
| Posted on Saturday, March 03, 2007 - 03:35 pm: |
. And her name was, Mrs. ... ? |
Post Number: 6136 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 03:45 pm: |
Tuesday. Ruby. Hey, I was a kid. |
Post Number: 6137 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 03:46 pm: |
pssst, she didn't ask my name. I'm the drummer, remember? |
Gold Member Username: My_rantz
Australia
Post Number: 1229 Registered: Nov-05
| Posted on Saturday, March 03, 2007 - 03:51 pm: |
And it was goodbye Ruby Tuesday! |
Post Number: 6144 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 04:14 pm: |
Who could hang a name on her? Still I miss her. Slow day on the forum. |
Post Number: 6145 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 04:21 pm: |
Robert, I really want to know about your speaks, my brother has them now. |
Dallas,
TX
Post Number: 9919 Registered: May-04
| Posted on Saturday, March 03, 2007 - 04:41 pm: |
. What a rock and roll god. |
Post Number: 6148 Registered: Dec-04
| Posted on Saturday, March 03, 2007 - 04:47 pm: |
Back to Robert's speaker Q. |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 12:13 pm: |
Hi guys They are SPL-4000 they have 2 x 10" speaker and a tweater, the size is 12.75" x 15" x 42.75"h. Robert |
Post Number: 6184 Registered: Dec-04
| Posted on Sunday, March 04, 2007 - 12:37 pm: |
Robert, I had the 12"'s(5000's)? but the drivers are both peerless. You might pull a woofer and scan the unit for #'s, they may be available from someone else. BUT, if one is breaking down, the others will follow closely behind(barring physical damage.) Replacing one unit is taboo, and major repairs to one driver will disrupt the balance, if not perfectly accomplished. Ideally, you could replace the quartet, if the right drivers are available. Have you had the speakers apart? |
Post Number: 3 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 12:52 pm: |
No I didn't take it apart yet I was just trying to figure out the best thing to do. Robert |
Post Number: 6185 Registered: Dec-04
| Posted on Sunday, March 04, 2007 - 01:38 pm: |
Robert, I pm'd you back. You are going to have to open them up and get some info. If you got them cheaply enough, the replacement pars may work out well for another 20 years. I think yours are like 1983 or 4 |
