Thread: Martin Logan Dynamo vs. Hsu VTF-2? |
Bronze Member Username: Bebopdeluxe
Post Number: 17 Registered: Feb-07
| Posted on Friday, March 02, 2007 - 01:58 pm: |
Any thoughts? The VTF-2 seems like a giant-killer - particuarly at the $250 price point that a used one can be found on at Audiogon...but the Dynamo seems to get its share of respect as well. Music only - no HT. Thanks! |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 412 Registered: Apr-06
| Posted on Friday, March 02, 2007 - 03:02 pm: |
Note that there are several different iterations of the VTF2, so that will affect the outcome. At 250 bucks though, I'd say any of them would be a great value. On the other hand, the Dynamo is a great music subwoofer; however, its output will be somewhat limited compared to the VTF, so if your room is large, or you like to blast it, the Dynamo might not be the best choice. |
