Thread: Car speakers for home use? |
New member Username: Gurpreet
Post Number: 8 Registered: Jan-07
| Posted on Monday, February 26, 2007 - 07:06 am: |
Its a thought... I have a Denon stack system... which is 2x30w RMS into 4 ohms... anyhow... the speakers I have are from an old Technics mini system and they are 100w @ 6 ohms 89db... So I was experimenting.. and I put on a 5 1/2" component... Infinity Reference 5010cs... and it sounded really good... its rated 90w RMS max at 4 ohms and is sensitive to 92db I think... but it'd sound better with the cross over I bet... Good idea or bad idea? The design seems the same in the form of connections etc and basket structure. |
Relevant Product Info
Silver Member Username: Gamerdude
Ontario
Post Number: 420 Registered: Apr-06
| Posted on Monday, February 26, 2007 - 06:39 pm: |
The amp is 4ohms Same with the speakers they match works fine |
Platinum Member Username: Project6
Post Number: 13129 Registered: Dec-03
| Posted on Monday, February 26, 2007 - 10:33 pm: |
It is an idea. Whether it is good or bad depends on how you define what. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9875 Registered: May-04
| Posted on Monday, February 26, 2007 - 11:10 pm: |
. Define "what" or define what? |
Post Number: 13135 Registered: Dec-03
| Posted on Monday, February 26, 2007 - 11:13 pm: |
Yes |
