Thread: Intermient hum in the receiver |
Bronze Member Username: Ssin680
Post Number: 16 Registered: Feb-07
| Posted on Friday, February 23, 2007 - 12:46 am: |
Hi, I just installed my new system including a Harman Kardon AVR 445 receiver and when the receiver is in use for a certain time (15 to 30 minutes) I begin to get an intermitent noise coming from the receiver itself. It lasts about 2 minutes, then stops, then begin again a few minutes later, etc.. Any help will be appreciated ! Charles |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9844 Registered: May-04
| Posted on Friday, February 23, 2007 - 10:30 pm: |
. "Sounds" like a cooling fan switch in and out. |
Post Number: 17 Registered: Feb-07
| Posted on Monday, February 26, 2007 - 09:46 am: |
Hi, Is this "normal" with this receiver or is there a way to attenuate it ? Charles |
Dallas,
TX
Post Number: 9865 Registered: May-04
| Posted on Monday, February 26, 2007 - 10:37 am: |
. You'd have to ask either the dealer or HK whether it is "normal". If all is as should be, there isn't any reason to lower the volume of the fan as that would lower the benefit of the fan. |
