Home > Message Board > Home Audio > Speakers > Archive through March 08, 2007 > Help choosing a Power Cable (I know w...
Author Thread: Help choosing a Power Cable (I know wrong forum, please read)
Username: Uback007
Post Number: 149
Can anyone recommend a good bang for the buck power cable to upgrade to?
Yes, I just saw that there was a "power conditioning" section in the forum and because I am in the market for cables, it's the first place I came. However, that board is not very frequented, so I am posting here.
Please help! :-)
Username: Mike3
Wiley, Tx
Post Number: 266
Elementcable.com, excellent bang for the buck, whoever it is fairly stiff. I have the Red Storm which I use with my Rega Apollo. I see that they now have a Signature series too.
Username: Mike3
Wiley, Tx
Post Number: 268
s/b however it is fairly stiff, not "whoever it is fairly stiff"
Username: Jingka99
Kuala Lumpur, Kuala Lumpur
Malaysia
Post Number: 114
Consider QED Qonduit, also good bang for the buck...
Username: Frank_abela
Berkshire
UK
Post Number: 1945
Isotek and Chord Co. make very good aftermarket power cables. Whatever you choose get your dealer to lend you a set before you buy! You may like the difference, but you may not.
Regards,
Frank.
Home > Message Board > Home Audio > Speakers > Archive through March 08, 2007 > Help choosing a Power Cable (I know w... [ « Previous ] [ Next » ]
