Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Htr 5960 remote help
Author Thread: Htr 5960 remote help
Username: Bigdish87
Frankford, On
Post Number: 11
Hi I bought the htr 5960 receiver ,i can get eveything to work except the tuner on the remote control to select the pretuned stations.I did a reset on the receiver but the tuner option on remote will not work,also the enter code button does not work very well.One question i have do you have to put in a code to get the remote to work from the box?put in code for tuner to work,I like the receiver just fine but it will be going back if i cannot get this resolved,by the way as somee one else said on this forum the manual is a nightmare.Thanks for your help.Tom
Username: Bigdish87
Frankford, On
Post Number: 12
Sorry i forgot to mention that this is a yamaha htr 5960 receiver remote.Tom
Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Htr 5960 remote help [ « Previous ] [ Next » ]
