Thread: 2 options / Need your comments |
Bronze Member Username: Ssin680
Post Number: 11 Registered: Feb-07
| Posted on Wednesday, February 14, 2007 - 06:03 pm: |
Hi, I just began to upgrade my home theater. My room is 12 X 18. I had a Denon AVR 1505/485 and Denon SYS 65HT for speakers. I use it about 85% for cinema and 15% for music. I changed my receiver for a HK AVR 445 and now I have 2 options for the new speakers. Option 1 - Paradigm ------------------- Center : CC190 Left/Right : Monitor7 V5 Surround (2): Atom Monitor Sub : PDR10 Total 1692 CAN$ Option 2 - Klipsch ------------------ Center : RC52 Left/Right : RB51 Surround (2): RB10 Sub : RPW10 Total 1422 CAN$ My questions : - How do these look like ? - Should I go with 4 surrounds ? - Are there some of them that should be replaced or upgraded Any suggestion and comment is more than welcomed Thank you Charles |
Relevant Product Info
Gold Member Username: Nuck
Post Number: 5858 Registered: Dec-04
| Posted on Wednesday, February 14, 2007 - 06:39 pm: |
Charles, what is missing with the Denon speaker kit? What do you want to improve? |
Post Number: 12 Registered: Feb-07
| Posted on Wednesday, February 14, 2007 - 07:16 pm: |
Hi, Hard for me to describe it in english because I'm french speaking but the sound is not well defined, there is no "color" and definition. It's like "flat". Charles |
Post Number: 5860 Registered: Dec-04
| Posted on Wednesday, February 14, 2007 - 07:37 pm: |
Charles, sorry about the English as a second language thing, it is stupid enough as a first language. You really MUST listen to each of these speaker brands(at least brands) to get a feeling for them. Speakers vary wildly, in performance and expectations via a receiver. Both speakers you list can be driven easily by you new receiver, but the receiver will only shine when you decide on the polish. You should include a good player for the system, and you might consider that first. A cd player is often better, a DVD that does music well is more money. Look into OPPO for a cdp. Quebec? |
Post Number: 13 Registered: Feb-07
| Posted on Thursday, February 15, 2007 - 09:33 am: |
Hi, I will listen to then on friday. The dealer doesn't sell HK. They have Denon, Yamaha, Sony, Marantz. Is there a receiver that would sound like the HK in those to help me make a choice ? I dont't know OPPO. Is there a specific model I should look at ? Yes I'm from Quebec ;) Thank you Charles |
Post Number: 15 Registered: Feb-07
| Posted on Saturday, February 17, 2007 - 02:27 pm: |
Hi, It's a done deal !! I listened to a few ones and I went with Klipsch RB61 RC52 RS42 RPW10 Since i did not receive my Hk receiver (should be monday) I just replaced the old Denon ones on my Denon Receiver and what a huge difference already !!! I also ordered an OPPO player. Should get it next week. Thank you for your help Charles |
Post Number: 5922 Registered: Dec-04
| Posted on Saturday, February 17, 2007 - 07:06 pm: |
That was quick! Bon Chance! |
