Thread: Quick question |
Silver Member Username: Langless28
Boston,
MA
Post Number: 681 Registered: Dec-04
| Posted on Sunday, February 11, 2007 - 11:38 pm: |
hey if i have the polk monitor 60's that are bi-wireable, and its nominal impendance is 8 ohms, what would each terminal be if i bi-wired them? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9759 Registered: May-04
| Posted on Monday, February 12, 2007 - 12:14 am: |
. And just how are we supposed to know that little bit of information? You'll have to find a review or technical paper for the speaker that shows the impedance swing of the entire speaker. Separate out the portions of the speaker above and below the crossover point(s) and determine what the average impedance of each section would be. . |
Boston,
MA
Post Number: 682 Registered: Dec-04
| Posted on Monday, February 12, 2007 - 09:39 am: |
can i just hook up a multimeter to each set of terminals and find out that way? and if the speaker has a recom. of 20-200watts and my amp puts out 120 at 8ohm and 150 at 4, would it be better to bi-wire it? |
Dallas,
TX
Post Number: 9760 Registered: May-04
| Posted on Monday, February 12, 2007 - 03:05 pm: |
. "can i just hook up a multimeter to each set of terminals and find out that way?" No. It would be easier to just call Polk. "and if the speaker has a recom. of 20-200watts and my amp puts out 120 at 8ohm and 150 at 4, would it be better to bi-wire it?" Wattage has nothing to do with why you bi-wire a speaker. Read through the archives, the topic has been discussed several times. . |
