Thread: Speaker Upgrade? |
Silver Member Username: Uback007
Post Number: 137 Registered: Mar-06
| Posted on Wednesday, February 07, 2007 - 06:26 pm: |
I am wanting to upgrade my Paradigm Titans V.4 a step-up - maximum I want to spend is $650. My set-up consists of a Cambridge Audio 640A V.1 Integrated, Cambridge Audio 540D dvd player, Anti-cable speaker cables, and Signal Cable interconnects. Any suggestion as to some speakers to check out would be much appreciated. |
Platinum Member Username: Project6
Post Number: 12819 Registered: Dec-03
| Posted on Wednesday, February 07, 2007 - 10:52 pm: |
What is wrong with the current set-up? Why do feel that you are "upgrading" by spending $650? What are your current speakers not doing now that you expect from an upgrade? |
Gold Member Username: Hawk
Highlands Ranch,
CO
Post Number: 1171 Registered: Dec-03
| Posted on Thursday, February 08, 2007 - 01:00 am: |
007: With a Cambridge amp (a bit laid back, with slightly rolled off frequency extremes), I would recommend some speakers that have a more aggressive sound--the amp and the speakers should balance out nicely. I would recommend either a pair of Monitor Audio Silvers or a pair of JMlabs Cobalt 806s. Saturday Audio offers the MA S2s on a closeout for $449: http://www.saturdayaudio.com/ Click on their "Deals Page" link on the left hand side and scroll down. Alternatively, check out the jmLabs Cobalt 806s from Audio Advisor, also a closeout, for $599: http://www.audioadvisor.com/prodinfo.asp?number=JMCO806 both are excellent speakers in their own right and mating them with your amp will bring out the best in both. If you aren't sure, I know AA will ship them to you with a 30 day home trial. Just a couple of thoughts for your consideration. . . |
