Thread: Car subs for home system |
New member Username: Brooksthepro
Post Number: 1 Registered: Feb-07
| Posted on Monday, February 05, 2007 - 08:15 pm: |
sorry if this topic has been discussed previously but i joined and am posting on this site from my cellphone so bear with me :-). i have 2 12' subs in a box from my old car stereo. i want to hook it up to my harmon kardon reciever. i know i cant directly hook up the subs to the speaker out's on the reciever. and i know i cant use a car amplifier easily for my system...... now. if i were to buy this amplifier (DFX HDJ2000) and run rca cable from my reviever's sub built in crossover (sub woofer out) to the amplifier i want to get. will it work fine?....i wanna know it will work before i spend $200 on the amp. TIA!!! -brooks |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 12760 Registered: Dec-03
| Posted on Monday, February 05, 2007 - 08:25 pm: |
It will work. All you really need is a proper amplifier that can drive the speakers. |
Post Number: 2 Registered: Feb-07
| Posted on Monday, February 05, 2007 - 08:37 pm: |
is the hdj2000 not a proper amp for this setup? see link: http://www.hollywooddj.com/dfxhdj2000.html |
Post Number: 12773 Registered: Dec-03
| Posted on Monday, February 05, 2007 - 08:39 pm: |
The amp can drive 4 ohm loads, just make sure that the speaker are rated at 4 Ohms. |
Silver Member Username: Gamerdude
Ontario
Post Number: 387 Registered: Apr-06
| Posted on Monday, February 05, 2007 - 09:27 pm: |
Bryston if you have the money |
Post Number: 3 Registered: Feb-07
| Posted on Monday, February 05, 2007 - 09:52 pm: |
ya my speakers are at 4ohms |
Post Number: 12783 Registered: Dec-03
| Posted on Monday, February 05, 2007 - 10:27 pm: |
Go for it and let us know how you like it. |
Post Number: 4 Registered: Feb-07
| Posted on Monday, February 05, 2007 - 11:06 pm: |
thanks alot for you input guys. i will let you know how i like the setup! |
