Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Peak indicator on Marantz receiver
Author Thread: Peak indicator on Marantz receiver
Username: Allears
Post Number: 10
Bought a used Nad 541i cd player from a friend and hooked it up with RCA wires and the Peak Indicator light comes on. Will it hurt anything if ignore it. It sounds way better using the DAC's in the player than the receiver.
Thanks,
Bob
Username: Nuck
Post Number: 5721
Bob, the player likely has more output voltage than the receiver expects. The receiver should not have an issue with this, and the indicator is not a protection indicator.
Maybe try the aux in, these are often more flexable than cd.
Username: Allears
Post Number: 11
Thank you Nuck, I'll give that a try.
Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Peak indicator on Marantz receiver [ « Previous ] [ Next » ]
