Home > Message Board > Home Audio > Receivers > Archive through December 29, 2003 > Improving TV sound
Author Thread: Improving TV sound
Bought an Aiwa receiver w/Dolby surround and DTS surround capability + a KLH 3-pc speaker set for use with Dolby pro logic to improve the tinny sound quality from a Phillips TV. Sound only out of center speaker when following operating instructions for hookup. What's up?
hi. Are you sure that you have the surround modes are set to the right position and that all the connections are set up right? please make sure that the speakers are the right specifications that the reciver manufacturer recommends you to use. Thanks for considering this!
lilly
Maybye you can try out this site : http://www.aiwa.com/support.asp and click on the "operating instructions" link and see if you cna find the most recent revisions of the manual there. they could have changed the manual and added some more tips :) hope that works, call them at 1.800.289.2492 and they'll gladly assist you! thanks!
rw1302
If you have a mono signal coming from the TV (both right & left inputs tied together) and you are running Dolby pro-logic, you will only have sound coming out of your center speaker.
untitled
please try t reply....aj... thanks. :)
Home > Message Board > Home Audio > Receivers > Archive through December 29, 2003 > Improving TV sound [ « Previous ] [ Next » ]
