Thread: New old amp and pre |
Gold Member Username: Nuck
Post Number: 5640 Registered: Dec-04
| Posted on Friday, February 02, 2007 - 11:13 am: |
So I have the 1973 Pioneer now, it needs a cleaning. I have nonresidual contact cleaner to hose it down. What a beauty. The pre has bass and treble for each channel, low and high bypass filters and norm/revertse(180 deg) selector. This thing has what would be a HT 5 yrs ago built in, but STEREO! Now, the Q. Both units have 20g lamp cord for power, non grounded. What should I use for power cord? I have 14g cap-tie(rubber shrouded 3-wire), should I use something else? I will solder on the stuff I have to try it out after the cleaning, but is there a better rec? |
Relevant Product Info
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9697 Registered: May-04
| Posted on Friday, February 02, 2007 - 12:06 pm: |
. Why do you think you have to change the power cables? |
Post Number: 5656 Registered: Dec-04
| Posted on Friday, February 02, 2007 - 02:39 pm: |
20g cables, 30 yrs old. Lamp cord. |
Dallas,
TX
Post Number: 9701 Registered: May-04
| Posted on Friday, February 02, 2007 - 10:32 pm: |
. Is the insulation in good shape? Any signs of deterioration on the cable or plug? |
Post Number: 5688 Registered: Dec-04
| Posted on Saturday, February 03, 2007 - 12:20 am: |
A bit frayed at a long term bend in the cable. Like arond a corner for 20 yrs or so. |
Post Number: 5699 Registered: Dec-04
| Posted on Saturday, February 03, 2007 - 11:49 am: |
Well the pre will not power up at all, and the ingress to the power connections are via 30 year old Reed and Prince screws, covered in shite. I may have to cut the screws with the Dremmel, losing the original screws in the process. Yeehaw. Not. |
Dallas,
TX
Post Number: 9706 Registered: May-04
| Posted on Saturday, February 03, 2007 - 12:26 pm: |
. Nuck, you need to let your wife decide which power tools will be required. Just hope she doesn't choose her new chainsaw. |
Post Number: 5701 Registered: Dec-04
| Posted on Saturday, February 03, 2007 - 01:49 pm: |
Jan, if you could skate, I AM a defensman. |
Post Number: 5755 Registered: Dec-04
| Posted on Monday, February 05, 2007 - 11:18 am: |
I met up with a local guy today, via my BIL. This mechanic/garage owner guy is a Pioneer lunatic. He has stacks 6' tall. Spec4 amps(3), Spec 1 preamp, dual 26 band EQ's. 4 tape decks,want a mint PT 2150 deck? $300CDN. Manual bias, manual tape set, 5 zillion buttons, a nice studio. 2 sets of speaks, stacked(it ain't a great listening room), HPM700 and HPM900. He has a set of 100's upstairs, but needs a woofer. And his buddy has 5x more than that! Who says Canadians can't have rednecks!? |
