Thread: SDAT 8" Subwoofer |
New member Username: Brettw
Post Number: 1 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 12:34 am: |
Hi, First post, sorry if it is a repeat. But what is the story with the SDAT 8" sub? I just read a VERY long post on the SDAT 404 speaker, so I'm now inclined to believe that this unit may be OK, not great , but OK. Trying to stay low priced, but willing to spend more if I get a much better product. thanks, Brett W All comments are appreciated |
Bronze Member Username: Gavdawg
Post Number: 100 Registered: Nov-06
| Posted on Saturday, January 27, 2007 - 04:27 pm: |
SDAT may not be the best bet. MartinLogan had the Dynamo on closeout at Magnolia for $300 of $399, which is a steal for this subwoofer. It is truly a great performer, especially for that price. |
Gold Member Username: Nuck
Post Number: 5572 Registered: Dec-04
| Posted on Saturday, January 27, 2007 - 05:30 pm: |
The white van is shopping subs now? |
Post Number: 3 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 06:43 pm: |
didn't see the van, it may have been repainted to almost any neutral color. Fact is I'm torn between a cheap new sub, older (maybe good) used JBL 12" sub and the Martin Logan if I could find it for 400 and not the 600 Best Buy sells it for. |
Post Number: 5577 Registered: Dec-04
| Posted on Saturday, January 27, 2007 - 07:16 pm: |
Try what you want, brett, I would shoot for the ML. I have zero experience with SDAT, just the buzz on the forums that say white van. It may be covered in shelfpaper. Quick getaway. |
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1328 Registered: Mar-05
| Posted on Sunday, January 28, 2007 - 11:25 pm: |
I love JBL but their subs suck, I would go for the ML or maybe HSU or SVS if you can deal with not hearing it first. Find a Jamo D4SUB and have your own slice of heaven would be choice number one hee hee |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 3862 Registered: Feb-05
| Posted on Monday, January 29, 2007 - 07:13 am: |
If Magnolia still has the ML Dynamo in silver you can get it for less than $400. |
