Thread: Denon 1907 or Onkyo 604 |
New member Username: Anujitd
Post Number: 1 Registered: Jan-07
| Posted on Friday, January 26, 2007 - 04:15 pm: |
hi, I cant decide between a Denon 1907 and Onkyo 604. Help |
Relevant Product Info
Bronze Member Username: Hodedofome
TX
Post Number: 36 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 08:54 am: |
Sorry to hear that. |
Silver Member Username: Arande2
400dB could probably d...,
SouthWest Mi...
Too Many DBs...
Post Number: 980 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 08:59 am: |
I'm almost crying!
Gold Member Username: Nuck
Post Number: 5558 Registered: Dec-04
| Posted on Saturday, January 27, 2007 - 09:08 am: |
AD, are there any other options? What features do you require? |
Silver Member Username: Thecrypt
Lawrence,
Kansas
Post Number: 120 Registered: Dec-06
| Posted on Saturday, January 27, 2007 - 09:21 am: |
Hi, I'm going out of town on business. See ya. |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 3844 Registered: Feb-05
| Posted on Saturday, January 27, 2007 - 10:30 am: |
On paper they look fairly even. Get the best deal you can on either. Hopefully you are driving efficient speakers. Andre, is that a self portrait? |
Post Number: 4 Registered: Jan-07
| Posted on Saturday, January 27, 2007 - 10:41 am: |
sorry I am new here. I am planning on getting POlk M50s, M30s, CS1 and a PSW10. I am more keen on the Denon because of the bi-amping facility and that should mean good clarity at medium - low volumes. is that right? Are there any other advantages? |
Post Number: 5568 Registered: Dec-04
| Posted on Saturday, January 27, 2007 - 04:04 pm: |
Bi-amping? Do you mean 2-zone? AD, we gotta talk. Describe EXACTLY what you want this unit to do. If you include speaker models(not just brands) we can walk through this together. |
Post Number: 5569 Registered: Dec-04
| Posted on Saturday, January 27, 2007 - 04:06 pm: |
This is amps, you are looking at receivers, but thats OK. Lay out what you want to do, and what you have. |
Post Number: 5 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 04:02 am: |
Ok..This is the first time I am getting a Home theater set up The speakers are Polk. The models are - front - Monitor 50 X 2 rear bookshelf - Monitor 30 X 2..I am not looking at buying the rear surrounds yet to complete the 7.1 center - CS1 Sub - PSW10 Denon offers the bi-amping facility ( store language) which means that that the free rear surround outs from the receiver could be pumped back into the front speakers for better performance. does this help? I have a 10' X 15' area ( the distance between the front and the rear speakers will be 10'). its not really a den and the neighbors might not be too inclined towards loud music, so I am trying to make the best of what I get. Movies to music preference would be 60:40 at this moment, thats all the info I can give u guys so far. |
Albany,
Oregon
Post Number: 3850 Registered: Feb-05
| Posted on Sunday, January 28, 2007 - 10:53 am: |
Again either should be fine for your application. If you like the feature set better on the Denon then by all means go for the Denon and get the best deal you can. And for your application a Yamaha would work as well you may want to check the feature set on say the RX V689. |
Post Number: 6 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 11:31 am: |
thanks art, I googled Yamaha...They have a V659. I had a question though. The power ratings just mention RMS Output Power (20Hz - 20kHz) 100W x 7 RMS Output Power (1kHz) Total Power (20Hz - 20kHz) 700W From the little research that I have done, the THD% should be mentioned in the Watt ratings. this did not seem obvious in the specs. thoughts? |
Albany,
Oregon
Post Number: 3852 Registered: Feb-05
| Posted on Sunday, January 28, 2007 - 12:54 pm: |
It doesn't really matter relative to the products we are talking about here. The Denon, Onkyo, Yamaha are all going to skew the numbers to look better than they actually are relative to power. You are driving relatively efficient speakers in a small space and using a sub to handle the low frequencies so what you really are shopping for is features and sound. Each of these brands has a different sound and feature set. The V659 has been very well received by the audio press and I believe is a good buy in its price range....again allowing that you are using efficient speakers in a small to medium space. |
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1326 Registered: Mar-05
| Posted on Sunday, January 28, 2007 - 11:16 pm: |
In my op. I would go with the Denon, but then again I am bias ...... get it Bias......tubes.....:/ |
Albany,
Oregon
Post Number: 3863 Registered: Feb-05
| Posted on Monday, January 29, 2007 - 07:16 am: |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1885 Registered: Sep-04
| Posted on Monday, January 29, 2007 - 01:04 pm: |
Hello Anujit, I know the Denon AVR1907. In your size room, it will easily fill the space you have. It's not the last word in fidelity but it is a good robust receiver. I don't know the Polks at all, but their specifications suggest they are relatively easy to drive. This is why I think the AVR1907 would be able to do the job well. In terms of facilities, it has a good set of features. The biamping facility is a nice thing to have, although I don't think this is a major issue given that the Monitor 50s are 89db and 8 ohm. Regards, Frank. |
Post Number: 7 Registered: Jan-07
| Posted on Wednesday, January 31, 2007 - 04:05 pm: |
Hi All, Thank you for all your suggestions. I am going in for the Denon 1907. Until I break my head next.. Best, Anujit |
Albany,
Oregon
Post Number: 3868 Registered: Feb-05
| Posted on Wednesday, January 31, 2007 - 08:31 pm: |
Congrats and enjoy! |
Post Number: 5605 Registered: Dec-04
| Posted on Wednesday, January 31, 2007 - 08:34 pm: |
Good luck, ad. Wear a helmet next time! |
