Thread: Samsung Subwoofer cali |
New member Username: Emerson1
Post Number: 6 Registered: Jan-07
| Posted on Saturday, January 20, 2007 - 02:08 pm: |
I have a Samsung ht-q100 and I can't find anywhere to adjust the sound settings. I am not getting much bass out of the sub and I want to raise it, and from what I am seeing there is no knobs. I looked at the menu and couldn't find anything. I might just be missing a menu. any suggestions? |
Gold Member Username: Nuck
Post Number: 5446 Registered: Dec-04
| Posted on Saturday, January 20, 2007 - 02:18 pm: |
Kyle, post your receiver/amp and the settings. |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9644 Registered: May-04
| Posted on Saturday, January 20, 2007 - 04:05 pm: |
. If you can find no knobs on your subwoofer, there probably aren't any. The sub is likely meant to run off a specific system and the system will determine the amount of bass sent to the sub. Is this a home theater in a box type system? |
Post Number: 7 Registered: Jan-07
| Posted on Saturday, January 20, 2007 - 04:33 pm: |
http://www.bestbuy.com/site/olspage.jsp?skuId=7711185&st=samsung+2.1&type=produc t&id=1138086437442 That is the system I have. |
Post Number: 5456 Registered: Dec-04
| Posted on Saturday, January 20, 2007 - 04:50 pm: |
What you hear is what you get, Kyle. |
Dallas,
TX
Post Number: 9648 Registered: May-04
| Posted on Saturday, January 20, 2007 - 06:23 pm: |
. Put the sub on the floor in a corner. |
Post Number: 5465 Registered: Dec-04
| Posted on Saturday, January 20, 2007 - 08:37 pm: |
With 18" or so between all sides. |
