Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Marantz sr7001/ 8500 or AV9000 pre/pro
Author Thread: Marantz sr7001/ 8500 or AV9000 pre/pro
Username: Allears
Post Number: 8
Thinking about buying the 7001 or 8500. Then a co worker said he's selling his AV9000 for $500 and all i need is a 5 chanel amp to go with it.
The av9000 has no Discrete 6.1/ Matrix 6,1, Neo-6,Dolby Digital EX, Dolby Pro Logic IIx,Circle Surround II,well you get my point.
Right now i have the Marantz sr6400. Which of the 3 will sound better. My speakers are Monitor Audio 9i and 12i center Polk CSi5 rears.
Bob
Username: Nuck
Post Number: 5207
Bob, maybe turn things around a bit.
What is lacking in your system now?
Is this shortcoming likely to be rectified with a step-up in receiver?
Username: Hawk
Highlands Ranch, CO
Post Number: 1025
Bob:
Must agree with Nuck here--what do you think you are missing? If anything, I wouldn't change the receiver, but I might consider an outboard power amp if, and I say if, you have a large room that the Marantz is having a hard time filling. I fail to see what any of the units you asked about will make any real improvement in your sound.
Username: Allears
Post Number: 9
LOL, never thought about adding an amp to the receiver.
Thanks guys,
Bob
Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Marantz sr7001/ 8500 or AV9000 pre/pro [ « Previous ] [ Next » ]
