Home > Message Board > Home Audio > Amps > Archive through April 07, 2007 > Alchemist Axiom APD 26a
Author Thread: Alchemist Axiom APD 26a
Username: Develara
Post Number: 11
Hi
Has any one tried Alchemist Axiom Apd 26a integrated amp.... hows the quality , i am trying to buy a second hand which i will couple it with Wharfedale Evo 8 or Castle Isis series bookshelf speakers , any reviews on the amp?
dev.
Relevant Product Info
Username: T_bomb25
Dayton, Ohio
United States
Post Number: 1499
Mark Shifter the owner of av123 used to own this company and as far as i know and knowing Mark he still built great stuff back then,you might want to go over to the: www.av123.com and get on their forums,im sure you will find what you need to know.
Username: T_bomb25
Dayton, Ohio
United States
Post Number: 1500
I think hold that thought I'll find out if its the same company.
Username: Markdavid
It is very unfortunate that this company is closed .I used to own some of their products .Its very good in sound and also in buit .I think u can use both wharfedale and castle .it will make both ur speakers sound neutral.use proper cables and also check ur acoustics.
mark
Home > Message Board > Home Audio > Amps > Archive through April 07, 2007 > Alchemist Axiom APD 26a [ « Previous ] [ Next » ]
