Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > HK AVR-245 or Onkyo TXSR604 ???
Author Thread: HK AVR-245 or Onkyo TXSR604 ???
Username: Thieveryfan
OK, That yamaha I was looking at is gone (Ebay).
Which of these two should I get?
Harman Kardon AVR-245
or
Onkyo TXSR604
They seem very similar, I'm looking for HDMI and Zone 2.
Or am I missing another better receiver for the same price? Ciruit City has the Onkyo at 395 with tax until midnight tonight (tomorrow's ad says $499!)
Thanks Guys.
Username: Nuck
Post Number: 5081
Kurt, if they both do what you want, pick the one which is heaviest and has the higher power consumption.
ie: if the unit says 7x100w, but consumes only 450w, it is either a perpetual motion machine(get 2) or the cure for the worlds power issues.
Username: Gamerdude
Ontario
Post Number: 333
H/K
Allso look for the omne which consumes the most power like Nuke said
The Onkyo Tajes 7 Amps
Considering 0.8amps=100watts (so i have heard)
Looks lik the onkyo might be a little more powerful, its all in what you like allso
Username: Gamerdude
Ontario
Post Number: 334
Nuck** One** Like** Takes**
Well, I bought the Onkyo, the good deal made me jump and I like the back layout - I think the 2nd and 3rd zones are better in the Onkyo too. I hope it sounds good with my Mirage Omnisats (haven't heard them yet).
I'm putting it inside a cabinet, any suggestions on how big a fan I should build into this piece of furniture - diameter, CFM?
Also, a simple IR bridge that I can take a long run wire and attach it to the back of the receiver?
Thanks for the help again -
what's Nuck** One** Like** Takes** mean???? ha
Username: Gamerdude
Ontario
Post Number: 335
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=17234 76&CatId=2216
Nice kurt either amp would be perfect
Check out that fan its 130mm
Noise Level 16 dBA
Air Flow 54.4 CFM
Two or three of these would be perfect and there pretty qiuet
And the **Nuck one** , was me correcting my mistakes
Good luck with the case dude
Username: Gamerdude
Ontario
Post Number: 336
acually i dont no about the onkyo, but the H/K has two fans inside , but i keep mine open on top of my audio rack , like i said good luck with the case
Username: Nuck
Post Number: 5102
Kurt, was it the heavier one with the higher power consumption?
Username: Gamerdude
Ontario
Post Number: 337
H/K-30 lb (13.6kg)//65W idle, 540W maximum (7 channels driven)
Onkyo-25.1 lbs/// i couldnt find any info on the onkyo for power consumption
Username: Afrogt
Post Number: 36
You made the right choice, even though the HK is heavier is doesn't process audio via HDMI. You'd have to use an optical or digital coax connection.
Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > HK AVR-245 or Onkyo TXSR604 ??? [ « Previous ] [ Next » ]
