Thread: Bose Wave Cannon, That's Right...Bose |
Silver Member Username: Arande2
400dB could probably d...,
4000 isnt ev...
100,000dB FU...
Post Number: 284 Registered: Dec-06
| Posted on Sunday, December 24, 2006 - 05:10 am: |
This is a subwoofer Bose makes and it's supposed to be 25hz-125hz +/- 3dB... at volumes greater than 109dB..I mean what? It's 12' long and 17" in diameter...isn't that a bit big to create 25hz at 109dB?
Where it's thicker in the middle, that's where the 15" driver is. It's also where you can hook cannons together for more output. I just wondered if it'd be any good. |
Bronze Member Username: Leonski
Post Number: 78 Registered: Jan-07
| Posted on Wednesday, April 11, 2007 - 09:33 pm: |
looks to be a form of 1/4 wave tuned TL design. Nelson Pass built the ultimate PAIR called 'El-Pipe o' which were soemthing like 15feet high and made of SonoTube.....Real Home Wreckers if you had 18foot ceilings and 3 or 4 kw of amp laying around. Look 'em up....do a 'google' This is also a design that the DIY guys have latched onto.....works well and is fairly simple. |
Gold Member Username: Arande2
Extreme SQ FTW
Missouri
Post Number: 2310 Registered: Dec-06
| Posted on Thursday, April 12, 2007 - 02:03 am: |
Yeah I've learned about this since I posted that long ago. Thanks though.  |
Silver Member Username: Gavdawg
Upstate,
New York
Post Number: 590 Registered: Nov-06
| Posted on Thursday, April 12, 2007 - 09:35 pm: |
and people say that Bose can't produce deep bass :-P Some of the pro products are quite good IMHO. I have heard the Panaray LT multiple times, and it has never disappointed me. I wish I could say the same for the home speakers. |
Silver Member Username: Eib_nation
Ohio
EIBville
Post Number: 170 Registered: Jul-06
| Posted on Saturday, April 14, 2007 - 03:06 am: |
I hear their bass modules go reaaaaly low!!
Gold Member Username: Thx_3417
Bournemouth ...
Post Number: 3544 Registered: May-05
| Posted on Wednesday, April 18, 2007 - 11:04 am: |
That was used I believe in a cinema somewhere in Southampton during the mid 1980’s and one projectionist who works at the Odeon Wet Fish commented that they where dreadful for sub bass and that the JBL 4645 will leaves that Bose Wave Cannon in the dust! |
Upstate,
New York
Post Number: 605 Registered: Nov-06
| Posted on Wednesday, April 18, 2007 - 02:11 pm: |
They really aren't designed for sub-bass reproduction, especially going by the specs. Although, I don't know what the rolloff is after 25Hz. In a music system, these actually sound decent, and are fairly tight. The Carrier Dome has several of these... |
