Thread: Bose speaker grille repair |
New member Username: Vitony
Post Number: 1 Registered: Dec-06
| Posted on Monday, December 18, 2006 - 07:22 am: |
I need to replace the speaker grilles on my bose speakers. Accoustimass 7 series. How can I remove and replace the grilles |
Silver Member Username: Gamerdude
Ontario
Post Number: 310 Registered: Apr-06
| Posted on Monday, December 18, 2006 - 09:20 pm: |
Flat head screw driver |
Gold Member Username: Chitown
Post Number: 1319 Registered: Apr-05
| Posted on Tuesday, December 19, 2006 - 02:50 pm: |
Jammed straight through the middle of the thing Ken I don't think you can remove them. |
Ontario
Post Number: 318 Registered: Apr-06
| Posted on Tuesday, December 19, 2006 - 03:19 pm: |
yea bose is evil like that, They dont want you taking apart there stuff |
New member Username: Stang
Post Number: 1 Registered: Aug-06
| Posted on Wednesday, December 20, 2006 - 04:00 am: |
Use a pocket knife. Carefully put the sharp part of blade, the full length, between the grille and the enclosure(On the side of speaker). Now, gently pry up. The grille is press-fit on. It's been a while since I pulled off one of my grilles, so you made need to do the same procedure, except with the knife on the top/bottom of speaker. |
