Thread: Help, I'm not high tech! TV sound through stereo |
New member Username: Kbpuckman
Post Number: 1 Registered: Dec-06
| Posted on Wednesday, December 06, 2006 - 11:40 am: |
OK guys, I'm not high tech but need some help. I have a new sharp 37" flat panel LCD and want to know how to get TV sound through my stereo system. I have a Denon M51 DVD integrated player that sounds OK with 2 Bose 301's. I have the TV hooked up with the standard 3 wire cabel. Do I need to run more wires to get TV sound or am I missing some thing in the manual? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 9408 Registered: May-04
| Posted on Wednesday, December 06, 2006 - 01:41 pm: |
. Do you not have sound or do you not have good sound? Your owner's manual for the integrated player should provide the information you need. Check in the TV's manual for any instructions that might indicate you need to switch on an output to provide a signal to the amplifier. . |
Gold Member Username: John_a
London U.K.
Post Number: 4594 Registered: Dec-03
| Posted on Wednesday, December 06, 2006 - 03:11 pm: |
Kevin, probably you just need to get a cable and connect "audio out" on the TV to any input on the integrated player. |
