Thread: Totem Hawk |
New member Username: Steve_g
Charlotte,
North Carolina
United States
Post Number: 10 Registered: Apr-06
| Posted on Monday, December 04, 2006 - 04:42 pm: |
Has anyone heard the Totem Hawks? I am looking to upgrade and have heard all of the Totems except for that particular one. Any advice would be appreciated. I am running a Rega Cursa/Maia combination with a Apollo CD player. |
Bronze Member Username: Steve_g
Charlotte,
North Carolina
United States
Post Number: 11 Registered: Apr-06
| Posted on Tuesday, December 05, 2006 - 04:17 pm: |
By the way, I can get the Hawk for about $1500.00 US. |
Gold Member Username: T_bomb25
Dayton,
Ohio
United States
Post Number: 1474 Registered: Jun-05
| Posted on Thursday, December 07, 2006 - 03:37 pm: |
They are very warm and forgiven of your electronics,one of the few Totems to work well with modest electronics along with the Staff and the Mite.If you like their sound you will love them,they have very deep shocking bass extension,with a huge soundstage and lovely midrange,i like them very much my self,nice speaker,have fun auditioning them. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1743 Registered: Sep-04
| Posted on Tuesday, December 12, 2006 - 10:39 am: |
I'd second that. Hawks would work well in that system. Regards, Frank. |
Bronze Member Username: Mitchbd
Post Number: 88 Registered: Feb-04
| Posted on Saturday, December 16, 2006 - 12:45 am: |
I'll third that motion. I have a pair myself, and they move me every time I sit for a listen. |
Charlotte,
North Carolina
United States
Post Number: 12 Registered: Apr-06
| Posted on Saturday, December 16, 2006 - 11:21 am: |
Will I need to use a Sub? Thanks for the responses everyone. |
Post Number: 90 Registered: Feb-04
| Posted on Saturday, December 16, 2006 - 08:13 pm: |
There is sufficient bottom end in the Hawk for my taste, and set-up. It really depends on the size of the room, and how much bass response you like. The Hawks will give you a very natural presentation of what's recorded. |
New member Username: Bflo_barry
Post Number: 1 Registered: Dec-06
| Posted on Saturday, December 30, 2006 - 05:43 pm: |
Has anyone A-B'd them with B&W? I am thinking of upgrading to the 804's, but Totem is also in the picture. Thanks, Barry |
Dayton,
Ohio
United States
Post Number: 1481 Registered: Jun-05
| Posted on Sunday, December 31, 2006 - 03:19 am: |
I like the Hawks better,the B&Ws are a bit overpriced,they are good but their is a bunch thats better at the 804s pricepoint and they are very power hungry,I think the Hawk is a better overall selection,they are very forgiving of electronics something thats unusual at this pricepoint,you can come out much cheaper,and the Hawks go a little lower than the 804s. |
Berkshire
UK
Post Number: 1775 Registered: Sep-04
| Posted on Tuesday, January 02, 2007 - 12:24 pm: |
Stephen, I don't believe you need a sub with Hawks. They have a very big sound, and that's not even considering the fact they're a fairly small floorstander. Regards, Frank. |
Charlotte,
North Carolina
United States
Post Number: 13 Registered: Apr-06
| Posted on Tuesday, January 02, 2007 - 06:52 pm: |
Thanks Frank. I can't wait to get them. Stephen |
Charlotte,
North Carolina
United States
Post Number: 14 Registered: Apr-06
| Posted on Tuesday, January 02, 2007 - 06:53 pm: |
Frank did you know that the Hawk is the speaker Vince uses at home? |
Berkshire
UK
Post Number: 1788 Registered: Sep-04
| Posted on Wednesday, January 03, 2007 - 01:22 pm: |
Stephen, No I didn't! That is a surprise. Regards, Frank. |
Charlotte,
North Carolina
United States
Post Number: 16 Registered: Apr-06
| Posted on Monday, January 22, 2007 - 06:23 pm: |
I am very close to buying the Hawk but had a question about it's ability to play loud. The spec reads 107db although I don't plan on playing this speaker particularly loud. Do I run the risk of damaging the coils at moderately loud levels? |
Berkshire
UK
Post Number: 1857 Registered: Sep-04
| Posted on Tuesday, January 23, 2007 - 01:05 pm: |
Steve, You'll only damage them if you play loud for really prolonged periods. Are you planning on partying the night away? If so, you should consider the Forests, which would also work well with the Cursa/Maia. Other than that you'd be looking at the Mani-2 Signatures, but a) they're much more expensive and b) you need exxons, and preferably 4 of them to biamp. Regards, Frank. |
Charlotte,
North Carolina
United States
Post Number: 17 Registered: Apr-06
| Posted on Wednesday, January 24, 2007 - 09:43 am: |
The max I would listen to them would be about 80-85db. I'm really looking for quality over quantity in this situation. |
Berkshire
UK
Post Number: 1863 Registered: Sep-04
| Posted on Wednesday, January 24, 2007 - 11:18 am: |
I can't see how this would be a problem with a Cursa/Maia unless you were sitting miles away from the speakers. Regards, Frank. |
Charlotte,
North Carolina
United States
Post Number: 18 Registered: Apr-06
| Posted on Wednesday, January 24, 2007 - 10:48 pm: |
Well, they have been bought. I've begun the dreaded break in period. Thanks everyone for your input. I'm excited to see what they can do. |
Gold Member Username: Nuck
Post Number: 5542 Registered: Dec-04
| Posted on Thursday, January 25, 2007 - 05:54 am: |
So are we, Stephen. Good luck! |
Berkshire
UK
Post Number: 1870 Registered: Sep-04
| Posted on Thursday, January 25, 2007 - 07:20 am: |
We break in our speakers by facing them at each other right up against each other but not quite touching, wire up one speaker out of phase (i.e. red to black and black to red), put in a Mono recording of anything upbeat and hit play. Turn up the volume knob until it would normally be fairly loud. Walk out of the room and leave it playing on repeat for the weekend. If the speakers are really difficult to run in, we do it for a few weekends. Dynaudios need 3 or 4 weekends like this. Totems need a couple of weekends. Since the speakers are out of phase and a mono signal is in use, most of the sound is lost and the speakers are just driving each other. The sound you get is relatively quiet (just lean one to the side so they don't self-cancel and you'll see what I mean). If you do this when you go out for the day at the weekend, it will hasten the run-in process. Regards, Frank. |
Dayton,
Ohio
United States
Post Number: 1483 Registered: Jun-05
| Posted on Friday, January 26, 2007 - 10:27 pm: |
Or you can just grab you some beer get you some no-dose and just listen the whole weekend! |
Charlotte,
North Carolina
United States
Post Number: 19 Registered: Apr-06
| Posted on Saturday, January 27, 2007 - 03:09 am: |
THAT is a distinct possibility! |
New member Username: Lucagiub
Post Number: 8 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 09:53 am: |
Hi Jut a couple of days ago I happened to hear TOTEM HAWK with Linn's MAJIK System (majik 2100 - kontrol - cd). I don't know, the sound didn't really come out as expected. YEs, extremely powerful and yet natural response in the lower range, good sound stage and imaging but...the overall impression was the sound was a wee bit "thin" if you see what I mean, lacking somewhat personality and depth. Moreover, when we played Beethoven's piano sonata in e-flat major n. 18) quite loud but not too loud, we discerned some distortion in several chords. I don't know, it makes me wonder. I've listened to hawk in several combos (EXposure, Meridian and now linn, I won'r mention Cambridge..it was awful!) and these loudspeakers seem to work well only with Meridian. luca |
New member Username: Scottfenwick
Post Number: 1 Registered: Jan-07
| Posted on Sunday, January 28, 2007 - 10:09 am: |
help required please. I am upgrading my system to a planned system of totem hawks to be driven by an arcam avr 300. I will also be getting a rainmaker centre. Any thoughts on this configuration or advice to other setups would be great. Also any advice on cables. thanks for the input. scott |
Charlotte,
North Carolina
United States
Post Number: 20 Registered: Apr-06
| Posted on Sunday, February 11, 2007 - 07:16 am: |
The break in period is over and MAN could I tell a difference. I was listening to Beth Orton and the amount of detail that I heard was amazing. The Hawk is a downright fantastic speaker with surprising dynamic slam. Frank, you were right, I don't need a sub. Scott, I don't know that much about cables but I am currently using DH labs silver sonic interconnects and love them compared to what I had used before. I'm also using Analysis Plus Oval 10 Power Cords for all components. Although I couldn't tell much of a difference with the power cords attached to source components, I did notice a marked improvement when used with pre/power setups. Once again, thanks everyone for your valuable insight. I am a happy camper and would definitely recommend this speaker as it does a lot of things really well. By the way, It is also very beautiful. |
Post Number: 3 Registered: Jan-07
| Posted on Sunday, February 11, 2007 - 09:33 am: |
Thanks for the input stephen. I think that I am leaning toiwards nordost blue heaven, but just not sure if the are worth the money. Anyone ever use this speaker wire with the totem hawks. Thanks again. scott |
