Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > H/K Avr 245
Author Thread: H/K Avr 245
Username: Gamerdude
Ontario
Post Number: 290
I was at my local Futureshop looking some H/k amps mostly looking for the 245 but wasnt there. I was in the sound room with all of the speakers and such and they had a 660 i think seemed older becuase it had the old knobs for bass/treb/balance But when i turned the volume down to around 79/80 there was a slight pop which didnt really impress me. Has that changed with the newer models?, And are the front buttons as cheap as they feel?
Any advice would be great thanks
Username: Gamerdude
Ontario
Post Number: 291
Also what do you think on the 245 good/ bad?
Username: Petergalbraith
Rimouski, Quebec
Post Number: 1976
In general I like h/k, but they are much cheaper in the US.
Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > H/K Avr 245 [ « Previous ] [ Next » ]
