Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Any one Can suggest a good fourm abou...
Author Thread: Any one Can suggest a good fourm about home video and audio? I need some suggestion
Username: Tetete
I want to buy a recevier to hook up my ps3, xbox 360 and wii
I want to take the advantage of the features of ps3 and xbox 360 like Dolby TrueHD Dolby digital, DTS
any one have a good suggestions under $500?
I heard Panasonic is not that expensive, and is good as well, is that so ?
Username: Nuck
Post Number: 4652
te, the xr55 is ideal, but you need to go up to the xr75(85) for hdmi.
It will be perfect for you.
Username: Project6
Post Number: 11607
You spent plenty of money on your game systems, why skimp on the receiver?
What are you using for speakers?
Username: Tetete
ya, i would like to get a decent recevier,
but the ps3 and wii runs out my money these days,,
that's why
Username: Project6
Post Number: 11611
Man, that's too bad. The games are not that cheap!
Nuck's suggestion is excellent, though.
Username: Tetete
but Panasonic XR55 didnt have a HDMI
Username: Nuck
Post Number: 4683
te, the 75 or 85 does, I think.
Damn, where is Eddie?
My follow through on the Panny is not from personal preference, but the idea that gaming and the Panny would work well together. I have not put a lot of thought into the audio aspect of the system, and at this point, te may not have either.
Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Any one Can suggest a good fourm abou... [ « Previous ] [ Next » ]
