Thread: Best amp to feed Epos M15.2 speakers? |
New member Username: Brianabbott
UK
Post Number: 1 Registered: Nov-06
| Posted on Sunday, November 19, 2006 - 12:13 pm: |
Hi I'd appreciate any advice on the best amp to feed Epos M15.2 speakers. I've looked so far at the NAD C352 , but what other options should I look at? (I mostly play rock/blues at moderate volumes). Thanks |
Relevant Product Info
Gold Member Username: Artk
Albany,
Oregon
Post Number: 3679 Registered: Feb-05
| Posted on Sunday, November 19, 2006 - 12:58 pm: |
Creek 5350 SE or Destiny. Creek and Epos are made for each other...great synergy! http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1168521620 |
Bronze Member Username: Pether
Utrecht,
Utrecht
Netherlands
Post Number: 16 Registered: Mar-06
| Posted on Sunday, January 14, 2007 - 05:50 pm: |
In the past they said that Naim was the best combination. But Creek (also the cheaper ones) could now do the trick. Maybe Exposure is also a good choice. Have a good listen at home, first. |
Gold Member Username: Nuck
Post Number: 5238 Registered: Dec-04
| Posted on Sunday, January 14, 2007 - 06:47 pm: |
If you have a chance to hear a Classe amp, please do so. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1838 Registered: Sep-04
| Posted on Monday, January 15, 2007 - 12:50 pm: |
Creek owns EPOS. This is why they are such a god combination. You need to be looking at the more powerful creek amps for the M15.2. Naim is still a good combination (EPOS were originally designed with Naim amps as test beds). Any current Naim amp would do in smaller rooms. In larger rooms you'd be looking at the 202/200 pre/power. If buying second hand olive series, I think the minimum would be a NAP180 power amp. Match this with something like a 72, 102, 82 and you'd have a fine combination. Don't forget that naim amps sound bets with Naim speaker cable... Regards, Frank. |
Gold Member Username: T_bomb25
Dayton,
Ohio
United States
Post Number: 1501 Registered: Jun-05
| Posted on Friday, February 09, 2007 - 04:22 pm: |
The new Epos still sound better with the Creek gear,before they were voiced with Naim but that time has passed, Mike Creek bought Epos to voice with his amps SPECIFICALLY FOR THAT REASON!,so dont stray from that road trust me I found out the hard way,they are the obvious choice. |
Bronze Member Username: Jingka99
Kuala Lumpur,
Kuala Lumpur
Malaysia
Post Number: 89 Registered: Aug-06
| Posted on Friday, February 16, 2007 - 02:14 am: |
Brian, try the destiny series from Creek... |
