Home > Message Board > Home Audio > Speakers > Archive through December 21, 2006 > Speaker - computer help
Author Thread: Speaker - computer help
Username: Moron6000
I have two speakers/loadspeakers and i want to connect them to my computer. The problem is that the speakers only have the red/black speaker leads that do not connect to my computer. PLease help}
Username: Jan_b_vigne
Dallas, TX
Post Number: 9361
Depending on the speakers, you either need a soundcard with speaker outputs or the more likely situation is you need an external amplifier that can take a feed from your existing soundcard.
Username: Moron6000
what is an external amplfier and are thay purchasable for under £30.00
Dallas, TX
Post Number: 9363
For $30-40 dollars you should go the the shop where you bought your computer and buy some new speakers that are designed to run off your current PC.
Home > Message Board > Home Audio > Speakers > Archive through December 21, 2006 > Speaker - computer help [ « Previous ] [ Next » ]
