Thread: Strange New Development |
Bronze Member Username: Tvshopper
Post Number: 63 Registered: Mar-06
| Posted on Friday, November 17, 2006 - 09:39 am: |
I have a Yamaha HTR-5850 receiver that is driven by a Motorola DVR on Charter cable. Lately (within the past couple of weeks) when a commercial comes on on my high definition channels, there is no center or front sound. The only sound I get is surround and subwoofer. I have it set on Prologic surround. When the show comes back on the sound is fine. What is the problem? (I assume it has to do with the commercials not being encoded properly but I'm not sure.) How can I avoid it? Thanks for any input. |
Gold Member Username: Kano
BC
Post Number: 1119 Registered: Oct-04
| Posted on Saturday, November 18, 2006 - 02:10 am: |
Have you listened to any other sources with pro logic? |
Post Number: 66 Registered: Mar-06
| Posted on Monday, November 20, 2006 - 09:43 am: |
Yes and I don't experience the problem. Also, it is only evident with some commercials and some shows. Other shows and commercials on the same channels operate just fine. |
Silver Member Username: Jethro
Lansing,
Mi
Post Number: 124 Registered: Jan-06
| Posted on Wednesday, November 22, 2006 - 05:06 am: |
sounds like a source material matter at a glance, but I don't understand why your surrounds would be playing and not your mains. Check to make sure everything is hooked up correctly. I mean, in all honesty sounds like you have your rears wired to the front l/r channels. If this isn't the case, I haven't the slightest sorry if this doesn't help. |
Post Number: 68 Registered: Mar-06
| Posted on Monday, November 27, 2006 - 02:58 pm: |
I got it solved. Thanks for the help. |
