Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Which kind of receiver
Author Thread: Which kind of receiver
Username: Johnrob69
Oklahoma city, Oklahoma
I want to play just music, i dont really care about home theater, or surround sound, is there a better type of receiver better for just that
Username: Nuck
Post Number: 4612
The Outlaw R2150 stereo receiver is quite complete. It has high power, can drive difficult speakers, has a sub out with bass management and a phono section.
Username: Gamerdude
Ontario
Post Number: 263
Nice last name
Username: Frank_abela
Berkshire
UK
Post Number: 1735
John,
The best is to separate into an integrated amplifier and tuner. There are two benefits to this:
1. Both tuner and amplifier are likely to benefit from the quieter environment in their respective boxes.
2. You'll get far more choice. Receivers fell out of favour in the 90s so your choices are fairly limited. there are loads of tuner and amplifier separates.
At this point it'd be question of budget...
Regards,
Frank.
Username: Mike53
Post Number: 11
John, I've been researching receivers as well as tuners and integrated amps over the last few months. The choice of 2 channel stereo receivers is limited, as Frank pointed out. There are a couple very nice ones to choose from - check out NAD, Rotel, Music Hall, Yamaha, Marantz, Denon and the Outlaw, that Nuck mentioned. All are good choices it just depends on what options you require.
Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Which kind of receiver [ « Previous ] [ Next » ]
