Thread: Velodyne subs. |
Bronze Member Username: Craigblue
Post Number: 11 Registered: Sep-06
| Posted on Sunday, November 12, 2006 - 09:29 am: |
Hello everyone. I'm thinking about changing my sub to a velodyne sub. I'm using focal speakers chorus range 716 and 707 with a denon 3806 AV receiver. My space is 24x15x8. whcih of the following velo susbs u think will suits better to the mentioned speakers and space: SPL 1200R - DD10 - DD12, |
Gold Member Username: Touche6784
Post Number: 1141 Registered: Nov-04
| Posted on Sunday, November 12, 2006 - 10:15 am: |
dont double post. its annoying as hell. |
New member Username: Ih8attn
St.Catharines,
Ontario
Post Number: 2 Registered: Oct-06
| Posted on Sunday, November 12, 2006 - 02:32 pm: |
i have a Velodyne DPS 12 and for what i paid (400 cdn shipped on e bay) it was well worth the money |
Post Number: 12 Registered: Sep-06
| Posted on Monday, November 13, 2006 - 03:50 am: |
thanx ih8, what are your speakers and room measurements? |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1729 Registered: Sep-04
| Posted on Monday, November 13, 2006 - 10:35 am: |
Leo, FWIW I think the Velodyne would be a good combination with the Focals. However, you have more options. Of the three you mention I think a DD10 would suffice. However, another way to skin this particular cat for similar money would be to use 2 subs such as SPL1000Rs. Two subs often give a better result than one, partly because you can compensate better for room issues, partly because the subs become less obvious (even though you can't hear the sub directly you can hear its effects coming from its area). The theory is fairly sound. The optimal positions for a two sub setup are in the middle at the front and in the middle at the back of the listening area. If this is not possible, they can be setupat diagonal opposites or in the stereo position near the front main speakers. Velodyne subs are really capable. The DD range are lovely because of their room EQ. However, if you went the stereo sub route with lower end subs, and you still wanted the EQ, you could always buy a Velodyne SMS-1 which can drive up to 4 subs at once and take care of the EQ through them at the same time if you wish. Different ways of doing things... Regards, Frank. |
Post Number: 13 Registered: Sep-06
| Posted on Sunday, November 19, 2006 - 05:58 am: |
Thanks frank,I really don't know the sw drive story; since my room is about 24x17, some of my friends say that never buy anything under 12", that's why I wanted to buy spl-1200R and velo guys say buy DD-10 it even can run a place up to 40x30 nicely! Is difference between these 2 that obvious? |
Post Number: 15 Registered: Sep-06
| Posted on Monday, November 20, 2006 - 03:22 am: |
or is the difference between 18hz and 22 hz that obvious? |
