Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Heed a little help
Author Thread: Heed a little help
Username: Texas_bass
Houston, TX
Post Number: 413
Im looking for a good quality and good price reciver you have any sugestions
Username: Kano
BC
Post Number: 1115
Pioneer + Yamaha have the most bang for the buck at the entry level IMO - Your post could give some more information though - such as the speakers you plan to use, what you consider a good price and what features you will use - ie what are your uses.
Username: Nuck
Post Number: 4562
As Kano said, your post is fairly wide open to interpretation, Thomas.
As a year-long member, you must be familiar with the 6 standard questions we will ask?
Houston, TX
Post Number: 414
its a bose system 2 satilites a center, 2 rears ans a sub the center and rears are 80 watts the satilites are 120 watts witch are connected to the sub and will be upgraded later most of my post are in car audio which i know a good amount of
Username: Riches1
Atlanta, GA
US
Post Number: 234
Harman Kardon also makes great entry level receivers.
Username: Riches1
Atlanta, GA
US
Post Number: 238
or marantz or denon. Check out Accessories for less.com or onecall.com for great prices on receivers.
Home > Message Board > Home Audio > Receivers > Archive through December 25, 2006 > Heed a little help [ « Previous ] [ Next » ]
