Home > Message Board > Home Audio > Equalizers > Can An Analog Equalizer Work With an ...
Author Thread: Can An Analog Equalizer Work With an SACD?
Username: Frank1203
Philadelphia, PA
Post Number: 50
Hello,
Is there any way to use my 2 channel analog equalizer to equalize a multi-channel connection for my SACD player?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9320
Two channels in and two channels out will EQ two channels.
Username: Frank1203
Philadelphia, PA
Post Number: 51
Thanks for your input, but I'm not sure I understand. The SACD has 6 wires that go into the Multi-Input of my Rotel Receiver, so how can I get it to two channels? I would guess there is a way to equalize just two of the 6 channels but I was hoping to be able to equalize all 6, or at least have the system divide the equalized front channels into the 6 speakers.
Dallas, TX
Post Number: 9347
Two channels in and two channels out means you can EQ two channels. I'm sorry, I don't know how to make any plainer than that. You cannot EQ six channels with only two inputs. You can pick any two of the six to EQ but you can only EQ two channels with two inputs. You can buy two more two channel equalizers and that would give you six channels.
Username: Nuck
Post Number: 4647
Frank, if you are using analog outs from your player, then the eq will work.
Username: Nuck
Post Number: 4648
Which eq?
Username: Nuck
Post Number: 4649
BTW, first time I read your profile. Very nice!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Equalizers > Can An Analog Equalizer Work With an ... [ « Previous ] [ Next » ]
