Home > Message Board > Home Audio > Mini Systems > Archive through July 30, 2005 > Active speakers or mini system?
Author Thread: Active speakers or mini system?
Hi
I already have a portable cd and md. Just wondering the following:
should I buy a pair of Jamo C-25 (C-5?) active speakers to match them ($180)
or
should I buy a mini system with an aux. plug for my md. The ones I have looked at are:
JVC UXP5R ($210)
Panasonic CPM03 ($200)
Sony CMT CP100 ($230)
The sound only has to fill a large bedroom and all I really want is some help on which option will give me the best sound for my budget.
thanks for your time.
Shannon
(nb. the prices mentioned are converted from British Pounds)
a friend
The active soundspeakers always have better sound quality than the passive solutions but they are less beautiful
I have a '94 Infiniti G-20. Panasonic radio/CD player came as original equipment with "Active speakers", front and rear. What do you recommend as replacement/upgrade for these speakers?
Home > Message Board > Home Audio > Mini Systems > Archive through July 30, 2005 > Active speakers or mini system? [ « Previous ] [ Next » ]
