Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Harman Kardon AVR 645
Author Thread: Harman Kardon AVR 645
Username: Mkdhaka
Alexandria, VA
Has anyone used AVR 645? If yes could you please let know your feedback including price and website. I appreciate the help in advance.
Username: Riches1
Atlanta, GA
US
Post Number: 235
Great receiver. Try going to onecall.com or B&H photo.
Username: Morrow
I just bought one @ Visions Electronics (Canada). I found a low price @ ecost.com and it displays the CDN dollar amount which helps. I went to visions there reg. price was $1788 it was on sale for $1588 and i showed them the online price from ecost.com added $200ish for duty and shipping, and they gave it to me for $1250CDN.
Good thing about Visions is you can buy the extra warranty and if you have no claims they mail you the store credit when the warranty expires if there was no use (this is rare). I don't have things hooked up yet but $1250 is a great price for this new product from a local retailer. It is a tad sketchy buying online when you're dealing with this kind of money.
Username: Orion
I recently bought an AVR645 as my first home theatre receiver. I found that volume to be kind of low. With minium volume at -80db and maximum at +6dB, I have to turn knob to at least -25dB in order to get some reasonable volume. Is this normal? I am troubleshoot with my old 45W/ch stereo amp, and the speakers are efficient (polk audio RTi10) and the problem seems to be the HK AVR645 itself. Can someone educate me?
Username: Nuck
Post Number: 5831
Orion, the receiver is a discrete output type.
This prevents small children from filling their diapers by twisting the loud knob(they love to).
Instead, more than one twist of a child's hand is required to get to the upper registers.
Play safe.
Username: Kano
BC
Post Number: 1143
Orion, I watch movies and some shows at -14dB - Rti8s/AVR430 - sounds pretty normal.
Username: Orion
Thanks Nuck and Kano. -14dB? seems not too far from its max +6dB. How much more volume can obtain without distortion? How many watt do you think it's giving out at -14dB?
Username: Nuck
Post Number: 5852
Sufficient, with reserves.
Username: Eramsey
South carolina
United States
Post Number: 514
Depends entirely on the speakers. This I know is rather meaningless, but anyway my front floorstanding speakers have 96dBl sensitivity and 4Ohm(nominal)impedence. With cd(coax digital) and dvd-same,any volume setting on my AVR335 above -35 is quite loud and at -10 my God man the walls and floor of the room(15x15) would be pounding and the one window would rattling! With analog inputs (2ch.) -25 would also be quite loud. Usual listening volume position is about -50to -40 The RT10 is a power hungry speaker up to 300Wrms and has fairly steep crossover(12dBl per octave-correct me if I'm wrong) and not very sensitive at 89dBl and would be best driven by a powerful amp in my opinion and in actuality I am confident this would hold true.
Username: Orion
True, and also the fact that your speakers are high in sensitivity and also 4ohm instead of 8ohm RTi10. Power output could increase by 50%. I have tested my RTi10 with my old stereo amplifier (Rega Brio) with some 40-50W/ch and is LOUD! At only 9 o'clock volume setting on Brio is as loud as -20dB on AVR645. That's the reason I questioned about the lack of power (which is not suppose to) from the AVR645. As Nuck suggested it's a safety feature, however I still haven't had the courage to crank up to over -5dB, it's sure loud at -5dB but close to the upper limit, distortion would be my concern.
Username: Nuck
Post Number: 5880
Orion, you may have just proven the quality/price conundrum.
Your Rega has more!
Username: Eramsey
South carolina
United States
Post Number: 515
That's a tough call then Orion, you can keep the AVR 645-fine receiver and find some more agreeable speakers( a bit higher sensitivity,less complex crossover) or find an amp for the RT10's(also a good speaker) which it is difficult to find a receiver to drive these speakers to their full potential,save a flagship which is a waste of money in my opinion since for the price of most flagship receivers you can get seperates that will offer much more.
Username: Nuck
Post Number: 5885
Orion, if you are using the receiver for HT and music, then you have a good unit.
For stereo listening, I back up ER above. Particularly if the stereo seperates come pre-loved from a good dealer.
Username: Gamerdude
Ontario
Post Number: 401
I've got the avr-245 and its fine about -25 is about normal volume
when i got mine to distort it was at about -9
i had four speakers running (fronts/rears)
and for some reason the volume only goes to +1 when running four channls
but it was pretty loud
it seems when i hit -20 -- -10 it when it really gets loud
When i game its usaly around -20
I dont have a sub
just two towers with a set of 10's one in each
Home > Message Board > Home Audio > Receivers > Archive through March 13, 2007 > Harman Kardon AVR 645 [ « Previous ] [ Next » ]
