Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 25, 2004 > Need advice for receiver
Author Thread: Need advice for receiver
Renato
I am upgrading from a Pioneer 811.
I brought home a Sony 2000ES. I like it but don't love it. I guess the digital sound is a little too flat for my ears. I was thinking about trying the 1000ES, since it's analog, it lacks some extra features of the 2000ES which I don't care for (dual zone, on screen menu) and cost a little less.
My other options would be the Onkyo 502 or the Yamaha HTR5750 (the only ones that are less than 6 1/2 in height and fit my cabinet).
Any thoughts?
Username: Landroval
Post Number: 132
If you need a small but nice sounding unit, you should check the new Cambridge Audio 540R and the NAD T742/T743/T752. They're a couple steps in front of Yamaha, Onkyo and Sony in terms of sound quality, and quite small in size.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 25, 2004 > Need advice for receiver [ « Previous ] [ Next » ]
