Thread: First Sub - Please Read |
Silver Member Username: W00b
Post Number: 209 Registered: Mar-05
| Posted on Thursday, September 21, 2006 - 11:14 pm: |
Hey guys. I'm looking into purchasing my first subwoofer for my system. I've been looking at the Dayton drivers mainly, but the subwoofer isn't my main concern. My current receiver has no sub-out or any type of output for that matter. However, my receiver is not exactly my "pre-amp". I have my system hooked up to my computer as follows: sound card output -> EQ input -> EQ output -> Receiver input The signal is actually controlled by my computer, which gave me a bit of an idea that may be able to solve my problem.. In my soundcard output I have an RCA cable, 1-male-to-2-male so it can go into my EQ. My idea was to buy another 1-male-to-2-male converter, and a 1-male-to-2-female converter. I would hook the 1-male-to-2-female into my soundcard, and then hook the 2 1-male-to-2-male cords into both my EQ and into my Sub, which would deliver signal to both. My only question is if this would work or not. Any other suggestions would be most appreciated! Dustin |
Platinum Member Username: Project6
Post Number: 11078 Registered: Dec-03
| Posted on Friday, September 22, 2006 - 11:06 am: |
What receiver is this? |
Post Number: 210 Registered: Mar-05
| Posted on Friday, September 22, 2006 - 02:10 pm: |
it's an AKAI AM-A70 .. I don't think you can find anything about it online because it's from 1984-ish and I think AKAI went out of business for awhile or changed something. |
Silver Member Username: Stefanom
Silver Spring,
MD
United States
Post Number: 177 Registered: Apr-06
| Posted on Friday, September 22, 2006 - 02:22 pm: |
It may work, but you could obtain a sub/plate amp that uses speaker line in connections; you connect the receiver to the sub w/ standard speaker wire connectors and then from the sub to your speakers. This would also cross your speakers over at a frequency of your choosing to reduce their burden somewhat. |
