Thread: Got a yamaha htr-5930 will athenas micra 6 work? |
Bronze Member Username: Silas92
Post Number: 94 Registered: Apr-06
| Posted on Monday, September 18, 2006 - 09:11 pm: |
Hey guys i just bought a yamaha receiver the htr-5930 i think its pretty good? got it for $170, are the athenas a good match or not? |
Platinum Member Username: Project6
Post Number: 10997 Registered: Dec-03
| Posted on Monday, September 18, 2006 - 09:18 pm: |
yes they are. |
Post Number: 95 Registered: Apr-06
| Posted on Monday, September 18, 2006 - 09:22 pm: |
thanx, You no any were I can get the athenas cheaper than Best Buy? oh yeh and was that a good deal on the yamaha? |
Post Number: 10998 Registered: Dec-03
| Posted on Monday, September 18, 2006 - 09:48 pm: |
try audioadvisor.com You can also go to the Athena Technologies website and check for authorized dealers. |
Post Number: 96 Registered: Apr-06
| Posted on Tuesday, September 19, 2006 - 09:48 pm: |
Yep i did nothing cheaper? ahh well i guess best buy is my best bet!!! lol never thought id say that. |
