Home > Message Board > Home Audio > Speakers > Archive through September 23, 2006 > Quick Question - Please Help
Author Thread: Quick Question - Please Help
Username: Tedora
Hi Everyone,
What a wonderful forum... I'll get to my question.
I am doing a very basic setup of 2 pairs of speakers, each in a different room.
I am looking for a simple way to install a switch that will turn each set on or off independantly. I don't need volume control of anything fancy. I was debating whether a light switch might do the trick... Nothing is high end so the loss of quality might not make a big difference?
Can it be done? Will it damage the amp to be hooked up this way? Which wire would be switched? The positive terminal?
Any other thoughts on inexpensive ways to do this..
Thanks very much... I really appreciate a response as I am trying to make all this happen today.
Thanks!
Al
Username: Eib_nation
Ohio
EIBville
Post Number: 133
Why not use the on/off switch on the receiver?
Username: Tedora
Why not use the switch on the receiver - because there are two rooms, and they are both running off of one connection on the receiver. The A part is running in a 3rd room, the B serves the other two... and I want each room to be able to turn off when needed...
Al
Ohio
EIBville
Post Number: 134
You'll need a multi-room remote to control your system from various rooms.
This is the kind of stuff you'll want to research to achieve your goals.
http://www.crutchfieldadvisor.com/learningcenter/home/multiroom_remote.html
Username: Petergalbraith
Rimouski, Quebec
Post Number: 1889
Interesting idea. So you will be using one room at a time? Otherwise be aware that the load on the receiver increases a lot (impedence lowers).
I can't think of a reason it wouldn't work.
Username: Tedora
Hi Rush,
Thanks for the link. I really can't spend much on this... This is a little project and the goal is to get as much done as possible without spending any significant money....
Peter, do you know if using a light switch in this way would work, and whether it would damage the amp in any way or which wire to switch?
Thanks for your feedback guys...
Al
Username: Timn8ter
Seattle, WA
Post Number: 1086
In ultimate cheap-ness you could just cut the one of the wires, strip them and connect them together when you want them to play.
To answer your question you could use a light switch or any number of toggle switches out there. All you're doing is opening or closing a low voltage circuit. It doesn't take much of a switch to do that. If you're not concerned about maintaining the highest fidelity possible then that's all there is to it.
HOWEVER, PG is right! You'd be wise to keep the volume down if you're playing both pair of B speakers at the same time. The impedance is likely to dip pretty low and fry your amp.
It's not unusual for speakers rated at 8 ohms to dip to 4 ohms. You put two in parallel and you're down to 2 ohms! Dangerous territory for many amps.
Username: Serniter
Piscataway, New Jersey
Post Number: 60
I would use two of these, one for each channel:
http://www.radioshack.com/product/index.jsp?productId=2062537&cp=&pg=1&origkw=to ggle+switch&kw=toggle+switch&parentPage=search
Would prevent connecting both speakers at the same time.
Username: Serniter
Post Number: 61
Wires from the negative terminal of the amplifier can probably go to both sets of speakers without interruption. Wires leading to the positive terminal would require this switch.
Home > Message Board > Home Audio > Speakers > Archive through September 23, 2006 > Quick Question - Please Help [ « Previous ] [ Next » ]
