Thread: How do you hook a surround sound up to ps2 |
Silver Member Username: Rick_ross
Post Number: 489 Registered: May-06
| Posted on Monday, September 11, 2006 - 10:35 am: |
is there any way to hook up a surround sound to ps2 |
Platinum Member Username: Project6
Post Number: 10789 Registered: Dec-03
| Posted on Monday, September 11, 2006 - 11:01 am: |
yo |
Gold Member Username: Kano
BC
Post Number: 1077 Registered: Oct-04
| Posted on Monday, September 11, 2006 - 03:06 pm: |
Just with analog, you can only use a DSP to simulate surround with a PS2. |
Bronze Member Username: Musicluvr
Post Number: 82 Registered: Apr-05
| Posted on Tuesday, September 12, 2006 - 03:47 am: |
Rick, Although I have not used it myself, my older model Sony PS2 has an optical digital out port. A quick search on Google confirmed that the PS2 supports 5.1 audio. So, as long as your reciever has an optical digital input port you should be able to directly connect your PS2 with an optical TOSLINK cable. |
