Home > Message Board > Home Audio > Speakers > Archive through September 23, 2006 > No bi amp speakers for a bi amp system
Author Thread: No bi amp speakers for a bi amp system
Username: Johnfish
CA
United States
I got a new micro stereo system that has inputs for bi amp speakers (hi and low). Is there a way to use my older non bi amp speakers with this system?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9110
Bi-amp on a micro system? Do you possibly mean bi-wire?
Username: Johnfish
CA
United States
The box says bi amp and bi wire. The speakers have four wires, two for high and two for low.
Dallas, TX
Post Number: 9112
Two wires for high and two wires for low can still be only bi-wired. The possibility might exist to bi-amp but the system might only be bi-wired from the factory. It is difficult to imagine a micro system including a second amplifier for true bi-amping. While some digital chip amps are relatively inexpensive, being inexpensive is usually a selling feature of micro systems. So the cost of an aditional amplifier and crossover for bi-amping seems unlikely to have been included. My guess would be you only have a bi-wired system which includes the potential for bi-amping. But that's only a guess since I don't even know the brand or model number of the system. This isn't a section of the forum where micro systems get much mention. You might try under "Mini Systems" or you might call your dealer. More reading of your owner's manual might turn up the answer, but as is, without the owner's manual available there is no answer I can give that isn't just a guess.
Username: Gamerdude
Ontario
Post Number: 173
Hey jan the panasonics mini systems do and the high are terrible High at full volume
http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelDetail?storeId=15001&c atalogId=13401&itemId=97238&modelNo=SC-AK640S&cacheProgram=11002&cachePartner=70 00000000000005702&surfModel=SC-AK640S&catGroupId=25015&surfCategory=Mini%20Syste ms&displayTab=S
4 wire per speaker and 4 inputs/channle,Now it may not be true Bi-amp but it dos the job
Dallas, TX
Post Number: 9113
I'll take your word for it though nothing in those specs indicates anything different that what I suggested above "Bi-amp/Bi-wire ... Yes" doesn't tell me much. Why would you possibly want to deal with either arrangement in a system like this? What possible benefits could there be? I do get the feeling this is just marketing hokum.
Username: Gamerdude
Ontario
Post Number: 175
Marketing Skeem they put it in so the buyer thinks it is more Professinal
Dallas, TX
Post Number: 9121
Those rats!!!!
Username: Gamerdude
Ontario
Post Number: 176
lol
Home > Message Board > Home Audio > Speakers > Archive through September 23, 2006 > No bi amp speakers for a bi amp system [ « Previous ] [ Next » ]
