Thread: Yamaha ysp-1000 |
Bronze Member Username: Winger53215
Post Number: 15 Registered: Oct-05
| Posted on Tuesday, September 05, 2006 - 12:02 am: |
ANyone have one of these? How do they sound?? |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4525 Registered: Mar-05
| Posted on Tuesday, September 05, 2006 - 09:52 am: |
Heard it at my local Tweeter...not bad for TV, gets pretty loud w/o much distortion. But nothing compared to real speakers with real surround sound. In short, you can do way, way better for the money. The only reason I'd ever buy this is WAF, WAF, and WAF. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1645 Registered: Sep-04
| Posted on Wednesday, September 06, 2006 - 08:37 am: |
You must have side walls without too much to break up the reflections for the YSP to work well. Plain side walls are best. If you have paintings or irregular walls (such as chimneys etc), then the YSP doesn't work very well. Regards, Frank. |
