Thread: Out of the box thinking . . . |
Silver Member Username: My_rantz
Australia
Post Number: 792 Registered: Nov-05
| Posted on Tuesday, August 29, 2006 - 11:53 am: |
Interesting concept, http://www.soundandvisionmag.com/article.asp?section_id=7&article_id=1279 |
New member Username: Manc
Post Number: 6 Registered: Aug-06
| Posted on Tuesday, August 29, 2006 - 12:12 pm: |
Link not workin for me. |
Australia
Post Number: 793 Registered: Nov-05
| Posted on Tuesday, August 29, 2006 - 12:15 pm: |
It works okay for me, though the speaker is the Jamo R 909 if you want to Google it. |
Silver Member Username: Stefanom
Silver Spring,
MD
United States
Post Number: 138 Registered: Apr-06
| Posted on Tuesday, August 29, 2006 - 12:24 pm: |
Reminds me a little of the Linkwitz Orion. It is indeed an interesting idea, albeit a bit pricey, considering they don't even have to fabricate a box! |
Post Number: 8 Registered: Aug-06
| Posted on Tuesday, August 29, 2006 - 03:05 pm: |
Seems like a good idea to avoid box colourations. Pricey indeed but more to spend where it counts more methinks. |
Gold Member Username: Timn8ter
Seattle,
WA
Post Number: 1067 Registered: Dec-03
| Posted on Tuesday, August 29, 2006 - 03:41 pm: |
Nothin' new, but I think you mean "no box" thinking. http://www.glacieraudio.com/new%20Glacier%20Audio%20Site/Products%20folder/Gilmo re/Gilmoreaudio1.htm and the aforementioned Orion. http://www.linkwitzlab.com/orion_us.htm Dipole speakers tend to be highly directional helping avoid some room problems. The commercial offerings usually have very expensive drivers designed to work in free air to deal with the loss of acoustical suspension and electronic EQ to help the bass response. |
Australia
Post Number: 797 Registered: Nov-05
| Posted on Tuesday, August 29, 2006 - 05:42 pm: |
Thanks for those links - I'd never seen these designs previously. I read somewhere that it takes a fairly powerful amp to work those R 909's so I suppose that applies to others of similar design considering your comments on the drivers. |
Seattle,
WA
Post Number: 1068 Registered: Dec-03
| Posted on Tuesday, August 29, 2006 - 05:58 pm: |
Dipoles aren't typically power hogs but it depends on the drivers used, of course, and how much equalization is applied. The R 909 is reported to have sensitivity of 89db and 4 ohm nominal impedance which isn't too bad. You can be fairly confident the impedance will dip under 4 ohms so a stout power supply would definitely be in order. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1618 Registered: Sep-04
| Posted on Thursday, August 31, 2006 - 09:20 am: |
Dey sho' is ugly dem dere speakers man... |
