Thread: Jbl SUB10 venue subwoofer |
New member Username: Fishairflow
Post Number: 6 Registered: Aug-06
| Posted on Monday, August 28, 2006 - 12:47 pm: |
any opinion on this subwoofer? bestbuy has it for 329 and I picked one up for 180...is this the right price???...is there a place I could have gotten it for a cheaper price?? One more thing - which of the following would it match with the most? I am using klipsch slx as two front and bose center chanel spearkers... 1. HK 635 open box US $ 369 2. HK 335 open box US $ 219 3. Yamaha 5860 open box US $ 120 |
Post Number: 9 Registered: Aug-06
| Posted on Tuesday, August 29, 2006 - 11:46 am: |
bump...guys really need help here... |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4500 Registered: Mar-05
| Posted on Tuesday, August 29, 2006 - 02:58 pm: |
JBL subs generally suck, I would look elsewhere. Closest in your price range would be Athena as-p4000 at $150, as-p6000 at $250 or Acoustech H-100 at $250. Google them up for dealers. |
Bronze Member Username: Darth
The woodlands
Post Number: 92 Registered: Aug-05
| Posted on Tuesday, August 29, 2006 - 03:30 pm: |
Kalia, $180.00 for that sub is a good price. That was a good budget buy. For the speakers you have the HK 335 Should work fine. Also, you might want to consider buying a Klipsch center channel to try to match your fronts. Good luck |
Bronze Member Username: Fishairflow
Post Number: 14 Registered: Aug-06
| Posted on Tuesday, August 29, 2006 - 05:09 pm: |
vader...i ended up buying the 635..there was not much differece...but the only reason why I have the bose vcs10 center channel is because I got that for a very cheap price.... now my issue is that the sub is not powerful AT ALL...for some reason it does not power up the subwoofer....and I know it is a minor thing...I just ndon't know what to change on the receiver... |
The woodlands
Post Number: 94 Registered: Aug-05
| Posted on Wednesday, August 30, 2006 - 10:15 am: |
Congrats on the 635...Have you set your speakers on your Receiver? With your set up I would set the fronts and center to "small" and the Sub-Woofer to 10". DId you try the EZSet/EQ on th 635? |
Post Number: 17 Registered: Aug-06
| Posted on Wednesday, August 30, 2006 - 06:52 pm: |
I just set it successfully - don't know excately what I did but I am going to reset it - and then see what happens...on the side note - For the JBL = retail was 329 and I paid 150 BRAND NEW.... I ahve an oppurtunity to get a Klipsch 10 " - which retails for 400 - for 150 - but this one is a FLOOR/DEMO model...any suggestions??? Please??? THanks guys... |
Gold Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 1840 Registered: Feb-04
| Posted on Wednesday, August 30, 2006 - 08:24 pm: |
Which Klipsch 10"? The Synergy Sub-10 has had good reviews. |
Post Number: 19 Registered: Aug-06
| Posted on Wednesday, August 30, 2006 - 09:07 pm: |
thanks peter....the synergy sub-10 - but you see while both can be had for 150 US $ - the Klipsch is a floor model at BEST BUY where as the JBL was brand new... I am so confused - I just don't want to regert this decision... |
Abubala,
Ababala
The Occupation
Post Number: 4504 Registered: Mar-05
| Posted on Wednesday, August 30, 2006 - 10:14 pm: |
kalia, put your mind at ease: buy the Klipsch, compare its performance to the JBL, and return the one you like less. One of BB's few redeeming qualities is its return policy, after all... |
Post Number: 20 Registered: Aug-06
| Posted on Wednesday, August 30, 2006 - 10:36 pm: |
aaah....you see - I think that the Klipsch rocks..it has the typical base....but the jbl has a lot tighter base...- but klipsch is more powerful..and matches with my slx speakers...and it has two speaker connections in teh back..and it looks more intimidating.... I want to get the best bang for my buck.... AAAAAAAAhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh |
Rimouski,
Quebec
Post Number: 1842 Registered: Feb-04
| Posted on Wednesday, August 30, 2006 - 11:01 pm: |
I'm surprised that the JBL has tighter bass than the Klipsch. Have you heard both in the same environment? |
Abubala,
Ababala
The Occupation
Post Number: 4506 Registered: Mar-05
| Posted on Wednesday, August 30, 2006 - 11:31 pm: |
kalia, if the only reason you're stressing out is because the Klipsch is not brand new like the JBL then I think you really shouldn't. A floor model from BB has the same return policy as brand new, if I remember correctly. Just examine it really closely to make sure it doesn't show any obvious signs of abuse, take it home and test it out thoroughly. |
Post Number: 21 Registered: Aug-06
| Posted on Thursday, August 31, 2006 - 09:26 am: |
yep..in the same environment - klipsch is louder but jbl is tighter.... The klipsch itself has a some scratch on the edge of the bottom part - but no damage per se...I am going to call klipsch and find out how old it is..... How can I test these woofers??? - I mean other than the obvious - movies and music... |
Gold Member Username: Nuck
Post Number: 4038 Registered: Dec-04
| Posted on Friday, September 01, 2006 - 10:45 pm: |
Kalia, if you can't test with your ears, the test is over. |
New member Username: Renko
Post Number: 1 Registered: Feb-07
| Posted on Tuesday, February 27, 2007 - 12:00 pm: |
Believe it Peter. The JBL SUB10 is much tighter than the Klipsch Synergy Sub-10. I think the JBL SUB10 goes a little lower than the Klipsch Synergy Sub-10 but am not certain if it simply seems so because it has such a tighter sound. I was totally surprised. I like the older model JBL speakers, but have not been impressed by their more recent products. I saw the JBL SUB10 at a local shop for only $150 and tried it on a whim. Now, I need to figure out how to get rid of my Klipsch Synergy Sub-10. |
