Thread: Help With NAD 763 not turning on |
New member Username: Halej
Mackenbach Germany
Post Number: 6 Registered: Dec-04
| Posted on Monday, August 21, 2006 - 08:10 am: |
Can somebody help. My T763 (previously working fine) will not turn on now. Orange light on front power switch on but no response from the unit. I unplugged and also toggled the rear power switch but still no response. It seams to be stuck in some kind of protection mode. Thank you |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1590 Registered: Sep-04
| Posted on Monday, August 21, 2006 - 08:59 am: |
First things to check: Unplug all speaker leads. Switch on. If it comes on, then it's likely one of the leads. Switch off and plug in one lead at a time to identify the one with the short circuit. If the speaker leads are out and it still doesn't come on you need to take it to your dealer for a checkup. Regards, Frank. |
Mackenbach Germany
Post Number: 7 Registered: Dec-04
| Posted on Wednesday, August 30, 2006 - 08:18 am: |
Thanks Frank -- Tried it - no luck . I also checked the 12 volt trigger switch. No luck there either. Looks like a trip to the shop. Thanks for your help |
Silver Member Username: Hawk
Highlands Ranch,
CO
Post Number: 942 Registered: Dec-03
| Posted on Wednesday, August 30, 2006 - 10:53 am: |
Is it time to change the batteries in the remote? |
Mackenbach Germany
Post Number: 8 Registered: Dec-04
| Posted on Thursday, August 31, 2006 - 03:10 am: |
Thanks Hawk - unfortunately, not (i don't think). Ive been pushing the button from the front panel. Is there some other magic I should know about? John |
Highlands Ranch,
CO
Post Number: 952 Registered: Dec-03
| Posted on Thursday, August 31, 2006 - 03:50 am: |
I was just suggesting that I had a similar problem at one point and it turned out my remote's batteries were too low to turn on or control the receiver, but they had enough power that the backlighting on the remote still worked, so I had no way of knowing the batteries were low. You can only be sure when you replace the batteries and everything works again. But that clearly isn't your problem since you tried using the power button on the front panel. Sorry I couldn't help. |
Mackenbach Germany
Post Number: 9 Registered: Dec-04
| Posted on Wednesday, September 06, 2006 - 09:34 am: |
Thank you gentlemen-- I got a repair estimate for 312 euro (about 410USD). However this includes a sofware ugrade to version 2.08. I think I currently have the oldest sofware version. It looks like the new sofware adds some considerable capability, Any ideas on what the saftware upgrade is worth (monetarily)? Thanks again |
Bronze Member Username: Jaw
Post Number: 41 Registered: Mar-06
| Posted on Wednesday, September 06, 2006 - 10:32 pm: |
JH, $410USD. What, specifically, was diagnosed as the problem? What, specifically, is the detailed fix? Thanks. |
Bronze Member Username: Halej
Mackenbach Germany
Post Number: 11 Registered: Dec-04
| Posted on Thursday, September 07, 2006 - 10:45 am: |
Well-- 43 euro About $50 was tax. I don't know german very well but I hope the attachement will help. I did have the 12 volt trigger switch replaced (i broke the toggle trying to figure if it was on, off, or auto)
Silver Member Username: Praetorian
Post Number: 429 Registered: Dec-05
| Posted on Saturday, September 09, 2006 - 12:57 am: |
Software upgrade should be free, you could probably do it yourself if you were do inclined. As to the hardware fix, you will have to sprecken the English before I can guesstimate the equivalent values between Europe and NA. |
Post Number: 430 Registered: Dec-05
| Posted on Saturday, September 09, 2006 - 12:58 am: |
"do" should be read as "so". |
Post Number: 42 Registered: Mar-06
| Posted on Saturday, September 09, 2006 - 07:55 pm: |
The properties of the PDF are locked; I can't transfer the copy and translate in babelfish. The shutdown problems appear to be widespread and would like to get some insight on the cause. Got the same problem with my NAD T752. $410 repair cost on a $999 investment is a 40% premium to pay on something that lasted 2 years. My NAD will probably wind up in a landfill. My thoughts, my experience with NAD. |
Mackenbach Germany
Post Number: 13 Registered: Dec-04
| Posted on Tuesday, September 12, 2006 - 03:13 pm: |
I turned off all locked properties maybe it will work, now. Micheal- I've done upgrades to my Denon 3910 DVD player but I've never found the upgrades available anywhere for the NAD.-- any Ideas? Thanks |
Mackenbach Germany
Post Number: 14 Registered: Dec-04
| Posted on Tuesday, September 12, 2006 - 03:20 pm: |
Sorry-- I tried the Babelfish idea and got the same problem -- the Electronics guy must have password protected the Doc. |
Mackenbach Germany
Post Number: 15 Registered: Dec-04
| Posted on Tuesday, September 12, 2006 - 03:35 pm: |
All this is the best translation I could come up with obviously some things just don't translate. Power pack repaired control section repaired 12 Volt Switch replaced Version 2.o8 Install defects Bauteille replace for alignment "durchgefuhrt" (this word has something to do with long term testing) turn out analog and digitally uberpruft DSP board modified - version T763 (not sure what this is) T763 keyboard assembly (not sure what this is) |
Post Number: 43 Registered: Mar-06
| Posted on Tuesday, September 12, 2006 - 09:12 pm: |
JH, Thanks for the input. Good to hear your NAD was repaired. Enjoy. |
Mackenbach Germany
Post Number: 17 Registered: Dec-04
| Posted on Thursday, September 14, 2006 - 04:45 am: |
All- just got everything hooked up and semi-calibrated last night. The new capabilities of version 2.08 are awesome! even with a quick calibration I can already hear better detail sound staging and balance. Not sure if it was the hardware or the software (then again- who cares!). This event may have delayed my required (self imposed) upgrade for at least a little while. thanks for your interest. john |
